Nice Luxman L430 100w/ch Duo beta integrated amp
geppy1
geppy1 Posts: 3,076
edited January 2012 in For Sale (FS) Classifieds
Nice Luxman L430 100 watt per channel integrated amp from their Revolver line of the early 1980s. Features their Duo beta circut and a nice moving coil/ moving magnet phono stage. Has bass and treble controls with tone defeat, phono straight, 2 tape inputs, tuner, DAD/CD, phono MM/MC ,preamp out and power amp in and can take two sets of speakers. Unit is in very nice shape with one small ding on the right rear corner of the cover. The original power cord has been repaired as I was using a detachable with it. All features and functions work as they should and the faceplate is very nice. Check my feedback. Asking $185 Thanks,keith
Form Integrated amplifier
Effective output 105W+105W (8 ohms, 1kHz, both channel)
THD 0.009% or less (8 ohms-3dB, 20Hz - 20kHz)
Cross modulation distortion 0.009% or less (8 ohms, 60Hz:7kHz=4:1)
Input sensitivity/impedance Phono man month: 2.5mV/50kohm
Phono MC: 100 microvolt/High-Low switching
Tuner, AUX/DAD, Monitor:200mV/40kohm
Main In: 200mV/50kohm
SN ratio (IHF-A) Phono man month: 90dB (input short-circuit, 5mV conversion)
Phono MC: 67dB (input short-circuit, 250-microvolt conversion)
Tuner, AUX/DAD, Monitor, Main In: 110dB
Frequency characteristic Phono: 20Hz-20000Hz?0.3dB
Tuner, AUX/DAD, Monitor, Main In: 10Hz - -100kHz one dB
Tone control ?8dB, a turnover shift type
Puri part output 200mV(Pre Out)
Light filter Subsonic Filter: 30Hz
A high cut-off filter: 7kHz
A low boost + 8dB, 70Hz
Tapes monitor Two lines (Tape-1, Tape-2)
Tapes dubbing 1->2, 2->1
Speaker switchpoint Two lines
Power consumption 220W
Dimensions Width 453x height 135x depth of 425mm
Weight 13.5kg
Post edited by geppy1 on
