Need help converting my RM6800 setup from 5.1 to 7.1
CAWjr
Unless I'm confused - your talking about adding way too many speakers. If you've already got 5.1 setup, you can't just go adding 4 more speakers and get 7.1 lol
Generally you can either run 7.1 by having the Fronts, Center, Sub and Rears (your standard 5.1 setup). The 7.1 gets you sides, OR front surrounds / highs.
Some people I believe have wired both, but they may be using 9 or 11 channel systems (or might even just be switching between the setups in the config?)
So, without knowing what your true intentions are - I just wanted to point out that (based on your statement) you're looking to add 2 too many speakers.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Glowrdr...Thank you for your reply. Since I realized I posted this in the wrong forum, I moved it, but I took the time to reply to you over there. Please take a look.
http://www.polkaudio.com/forums/showthread.php?127891-Need-help-converting-my-RM6800-setup-from-5.1-to-7.1&p=1700469&viewfull=1#post1700469
