Cardas Crosslink 1S
ANWKLO
ANWKLO Posts: 173
edited January 2012 in DIY, Mods & Tweaks
It has 4 conductors, can it be bi-wired? Is it designed for single-wire connection?
Post edited by ANWKLO on
    VR3 Posts: 29,537
    edited December 2011
    A conductor is a conductor - Im sure you could use it as a bi wire cable.
    EndersShadow Posts: 17,719
    ANWKLO wrote: »
    I would assume. I used Audioquests 14/4 wire to create bi-wire and bi-amp speaker wires. This wire seems to be about the same.
  • zingo
    zingo Posts: 11,258
    That's good DIY cable, and it can be used to biwire speakers, but remember to take into account the gauge size. I don't remember, but it may be rated with two conductors combined, so just ensure it is a large enough gauge for your wants/needs.
  • ANWKLO
    ANWKLO Posts: 173
    edited January 2012
    zingo wrote: »
    Each conductor gauge size is 10 awg, which is large enough. Yes, the factory made cable is two conductors combined.
