Speakers with 505
anilksharma
anilksharma Posts: 34
edited December 2011 in Speakers
Have the PSW505 Sub already, thinking to go either with RtiA5 or RtiA7. Which one would you recommend? Not planning to change the sub anytime soon. If an amp is a must with RtiA7, it would be few months before I invest in that.
Also, since bookshelf (Rti4) seems to be on crazzy deal these days, could they pair well with PSW505. Current apt size 14x20, budget up to about $700 is fine but really wanted to see if its worth to pay extra on top of RtiA5 when I already have a sub. 70% music, rest HT. Thanks
Post edited by anilksharma on
  • larry777
    larry777 Posts: 480
    I would go with the RTiA7's. The RTi4"s would also match well for the surrounds and the PSW 505 would fit in nicely as it was matched with the RTi line from the beginning. I have a similar setup only using the RTi10's in front (Similar model before the 7's with same drivers ) but later replaced my PSW 505 for an SVS Sub. The 505 will go in a downstairs setup, as I like it and didn't want to sell it. This time of year the 7's should go on for a good price.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • anilksharma
    Thanks Larry, with little research I can get RtiA5 pair for 450 but A7 for 700. Essentially you mean, its worth speding another $250 event if I have sub psw505. Would the difference in sound would be so much noticeable between both.
    Thanks again
  • larry777
    larry777 Posts: 480
    Newegg had the RTiA7's on sale two weeks ago for $299 and will likely have the sale again. Thats a good price for these towers. If the price is right for you, I would buy the 7's over the 5's. If budget is tight then the 5's may do you. Sub aside, I would always lean towards the best speakers overall especially considering future years when the upgrade bug could start to bite. For 2 channel music you may even find that the 7's would do nicely even without the sub, and would be the better option if you decided to add an Amp later on.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
    EndersShadow Posts: 17,722
    If your anywhere close to northern WI there is a forum member selling his pair of A9's for 450.
  • anilksharma
    Unfortunately, I am much far (West coast - Washington). Will keep checking Newegg.
