Mid Bass exsternal crossover
tommyt21
I was wondering if this was possible or even worth it. I want to add my PSW 505 back into my system as a Mid bass component only 50-150 Hz. I would like to use a Y splitter on my Sub RCA line. With one of them running directly into my HSU and the other with a inline exsternal crossover blocking anything below 50Hz, if thats plausable. Has anyone ever heard of something like this and if so where can I order such a esternal inline crossover?
The reason is because of where I have my RTI A7's placed and the HSU without the room to move them or the WAF. The Mid bass seems to get canceled or stifeled. I feel I am loosing some mid bass frequencies like Gun shots.
Any ideas are always appreciated.
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Fronts: RTi A7's
Surrounds: Rti A3
Post edited by tommyt21 on
I would think your gunshots would be more around the 250 to 750 range unless it was a battleship cannon.Too much **** to list....
Really?? That High?
I found this part on the net for my possible " mid bass module" http://www.parts-express.com/pe/showdetl.cfm?Partnumber=266-270Living Room
Fronts: RTi A7's
Surrounds: Rti A3
Acoustimac red suede panels -
I am sure I read a suppressor is designed for 170 to 3khz. That's where I would imagine is the most intense.
I found this article I think it gives more understanding than I could.
http://guns.connect.fi/rs/308measured.htmlToo much **** to list.... -
Sounds like your after something similar to the HSU MBM module.
Exactly but I think I can turn this PSW505 into a similar functioning unit.Living Room
Fronts: RTi A7's
Surrounds: Rti A3
You could use an Fmod. For 50 hz, it shows brown label is the closest.
Click on "Next Page" at the top of this webpage to see the offerings. There website sucks, but I have used this as bass blockers on door speakers in my cars for years. Great to have when you don't have an electronic crossover.
http://www.hlabs.com/technical/crossovers/HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
