Krell KAV-250A Power Amp
falconcry72
Anybody have any experience with this amp? How would it compare to my Parasound HCA-2200mkii? I'm looking for a step up, not a lateral move.
Thanks for any thoughts!
Ben
Ben
Post edited by falconcry72 on
FYI, both amps are rated at 250 WPC into 8 ohms, but the Krell supposedly truly doubles up to 500 WPC into 4 ohms, whereas the Parasound only makes 385 into 4 ohms.
I don't feel like I need more power, but I remember reading somewhere that an amp being able to double-up into half the ohms is an indication of good, err, stuff, or something like that.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
I have been looking up krell amps and considering the cost the krell should in theory smoke the parasound because of the high quality parts inside otherwise no one would pay a premium for the krell
I was looking 400 integrated and noticed from reading that it was 200 wpc and doubled into 4 ohms at 400 .Krell mislead the specs because it was actually higher than 200wpc but they wanted audiophiles to see that it doubled because its a good indication of a balanced design -
Saying as that company named itself based on the high power alien technology from "Forbidden Planet", I say yes.
Sometimes ratings are skewed, to imply doubling of power, don't know about the Krell. I have an older amp rated 200@8 ohms and 400@4 ohms. When Stereo Review tested it, it actually put out something like 265 watts@8 ohms, and just over 400@4 ohms. So it doesn't really double the power. Not that it matters, it has more than enough.
I did look for a review of that Krell, and I came across this:
http://www.cepro.com/article/krell_recalls_4_amplifiers/
So I would make sure it's been updated with the correct fuses if you get it. -
Good point, Jake.:rolleyes:
Thanks for the heads up. I'll check it out.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Your Parasound is on the warm side of neutral, the Krell will be more so on the bright, forward side but a tad more dynamic.HT SYSTEM-
lsi 9's -
I had that very amp & it was great!! I never got the feeling of it being bright but very dynamic which might give off that impression. It was dead on with the signal that it was fed...it simply pumped out gobs of sonic bliss. Krell has the reputation of being forward but that's probably because other amps in comparison just didn't have the same balls & ability of really bring it. If I was going to an amp fight I'd be bringing a Krell as my gun, the other amps would be akin to bring a lowly knife...not a fair fight. I probably shouldn't have let it go but I switched directions & went with my present Rotel multi-channel amp. I would highty recommend the Krell!!!
pearsall001 wrote: »I had that very amp & it was great!! I never got the feeling of it being bright but very dynamic which might give off that impression. It was dead on with the signal that it was fed...it simply pumped out gobs of sonic bliss. Krell has the reputation of being forward but that's probably because other amps in comparison just didn't have the same balls & ability of really bring it. If I was going to an amp fight I'd be bringing a Krell as my gun, the other amps would be akin to bring a lowly knife...not a fair fight. I probably shouldn't have let it go but I switched directions & went with my present Rotel multi-channel amp. I would highty recommend the Krell!!!
hmm. Glad to hear you enjoyed it.
What speakers were you running on that Krell?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
AAD 2001 Monitors. Pretty hard to drive & the Krell was always on easy street.
hmmm...
I'm trying to think if the KAV series is the one that should have the caps replaced or not. Service on them is not cheap so check into the age of the unit.
I know there was a discussion on Audiogon about some of the older Krells being priced high still even when they were needing to be gone thru which can add up quick when done. I thought it was the KAV line but I might be mistaken.
Either way a lot of the Krells I've heard tend to have very good bass response on them and are a bit brighter in sound. However they have gobs of power and can drive anything for the most part. -
I've got a Krell KAV-2250 with my SDA-1C's and it just rocks. Krell amps kick ****.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
falconcry72 wrote: »I don't feel like I need more power, but I remember reading somewhere that an amp being able to double-up into half the ohms is an indication of good, err, stuff, or something like that.
Yes and no depending on topology. Just don't get too wrapped around the axel about power ratings, or specs in general. I'd look more into sonic characteristics, as each amp will have it's own sound. Krell and Parasound will have different sonics which have very little if anything to do with 8 ohm and 4 ohm ratings.
In a nutshell, the 4 and 8 ohm ratings aren't going to be where the major differences are.
I think you should buy the Krell and PM me about buying your HCA-2200 MK II after the 1st when you make this all happen :cheesygrin:.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »I think you should buy the Krell and PM me about buying your HCA-2200 MK II after the 1st when you make this all happen :cheesygrin:.
Well, you're half right. I'm picking up the Krell tonight... but I'm keeping the Parasound!:razz:
My primary 2-channel rig used to be all Parasound, and I've been slowly but surely upgrading each piece. After this amp and a new CDP that's on the way, I will have replaced everything, so I'll have an all Parasound secondary rig.:cheesygrin:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
I hear ya. I'll be doing some A/B'ing starting tonight for the next couple weeks.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
falconcry72 wrote: »Well, you're half right. I'm picking up the Krell tonight... but I'm keeping the Parasound!:razz:
Excellent, I always like to be able to keep what I am using when I decide to do a change. The Krell will certainly sound different than the Parasound. So doing some comparisons after the parasound has been out of the main rack for a while might be interesting. You have to have stuff to try stuff!!!
RT1 -
I don't know those Ushers, but I prefer those Maggies with the parasound setup.
reeltrouble1 wrote: »...You have to have stuff to try stuff!!!
RT1
You said it, man. Reviews are nice, recommendations are cool too, but you gotta get your ears on stuff... in your setup. There is no substitution. This is pretty easy to do with used gear; you just have to know the market and have the patience to wait on a good deal, that way you basically get to try stuff for free. I did that with a few DAC's six months ago. I think I ended up out about 40 bucks between all three DAC's, but the experience was invaluable. Truly invaluable.
So, the Krell stuff is in the house. Oh, I had to get a KAV-250P too, cuz the woman wouldn't break it up, but it was too good of a deal to pass up. I wasn't even in the market for a power amp. I don't think this Krell is a keeper, but it will be the perfect stepping stone to the Bryston 4BSST I want, plus I get to free up the HCA-2200mkii for that secondary rig. Win, mother-effin win.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
No problem, but please keep me in mind if you ever do decide to let it go. That MK II is primo!VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »No problem, but please keep me in mind if you ever do decide to let it go. That MK II is primo!
Will do. And you're right. It is a special amp for Parasound; that's why I'm not convinced that I'll like the Krell more.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Some pics for all you audio pornaholics:
Well, the Krell definitely sounds different. I'll post a brief comparison review when I get home this evening.
I look forward to another great comparison from you
I need more time before an in-depth write up, but here's a quick first impression:
One word: dynamic. I wouldn't call the Krell bright at all; I'd call it detailed... extremely detailed... unforgivingly detailed. The bass response is more extended and punchy, very nice. The highs are more clear, but not bright.
I think both amps are pretty flat across the spectrum, but the Parasound is smooth whereas the Krell is articulate.
Any problems upstream will be out front for all to hear, that's for sure, but feed it a good signal and you'll be rewarded. Example: when I hooked up the Krell KAV-250P preamp, the combo was too bright. It didn't sound like music anymore; it sounded a little harsh. When I switched back to the LS-15... BOOM! Match made in heaven. I think this power amp really benefits from a tubed preamp.
Based on this KAV-250A and KAV-250P, I can see why someone would find an all-Krell setup to be bright or harsh, but the fault is not with the amp. Give it a good signal and prepare to be dazzled.
I actually had a hard time doing critical listening because I found myself so involved in the music. That's a very good sign.
:biggrin:
BTW I've only ran the Krell on my Magnepan 3.6's so far; I still need to try it out on the Ushers... actually, I still need to do a write up on the Ushers... I don't think I've really mentioned them yet... they're in maple.
Back that baby up with a killer tube Pre and you will be rockin.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I'm already there, man! ARC LS-15: (4) 6922's (Holland-made Bugle Boys from '64, Holland-made Amperex Orange Globes from '68, and my favs, Amperex White Label PQ's from '61):biggrin:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Nice! Mine is a combo balanced pre-amp and headphone amp that just plays real nice with the Krell. That combo plus the restored 1C's absolutely kicks ****.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
What? No love for Krell here? :question::question::question:2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
No love , but no hate either. Krell can be a little too forward for my tastes and everyone raves about the bass control. I've found the bass to be too mechanical and not organic or tactile enough. It doesn't seem as natural as some other amps I favor.
That doesn't mean it;s not a nice amp if that;s the type of sound you prefer. Really when it comes down to it at this level it's all about splitting hairs. Nothing glaringly obvious. Continue to listen to both for awhile and which ever one makes you tap your feet the most, keep.
