Differential signal levels
VelocityVinnie
Hi, my Head unit puts out a 1v differential line level.
Do any of the current Polk amps support differential input and high level input??
If not i may have to run my Polk speakers off another branded amplifier, but i would like to keep it all Polk if i can.
Does anybody have any experience of differential signals?
I know a lot of modern OEM headunits use it, as it eliminates noise ect
vin
vin
Post edited by VelocityVinnie on
It would probably be better to ask this in the car audio section. At least, I think this is a car audio question....Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Google is your friend, I don't know if they are still in existence, but some on use to make an adapter to go to a single ended output. I know, I know but wouldn't that defeat the purpose, not as long as you mount it by your amp and have a short run to it.
The Polk class D PA D4000.4 will take line level inputs. Check the manual for that amp.
I'd spend some money on a good quality line driver in your case.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
