Differential signal levels
VelocityVinnie
VelocityVinnie Posts: 20
edited December 2011 in Car Audio & Electronics
Hi, my Head unit puts out a 1v differential line level.
Do any of the current Polk amps support differential input and high level input??
If not i may have to run my Polk speakers off another branded amplifier, but i would like to keep it all Polk if i can.
Does anybody have any experience of differential signals?
I know a lot of modern OEM headunits use it, as it eliminates noise ect
vin
Post edited by VelocityVinnie on
  • quadzilla
    quadzilla Posts: 1,543
    It would probably be better to ask this in the car audio section. At least, I think this is a car audio question....
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Google is your friend, I don't know if they are still in existence, but some on use to make an adapter to go to a single ended output. I know, I know but wouldn't that defeat the purpose, not as long as you mount it by your amp and have a short run to it.
  • arun1963
    arun1963 Posts: 1,797
    The Polk class D PA D4000.4 will take line level inputs. Check the manual for that amp.
  • Vital
    Vital Posts: 747
    I'd spend some money on a good quality line driver in your case.
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
