week old Rti12 woofer rattle...
mediocreman
hello everyone,
I'm new to Polk and to forums but just needed some help here. I bought a pair of Rti12s new from Polk audio direct and got them setup and plugged into my emotiva XPA 5 with 200 wpc with my Onkyo TX-NR809 doing the processing. At reference volume the top woofer will rattle as if a piece of plastic is hitting in the center of the speaker. I removed the woofer to see if anything was hitting it like wires but nothing was. Is it blown? it doesn't scrap when when you move the woofer by hand. So I'm not sure what the issue may be. Any ideas?
Post edited by mediocreman on
Sounds like you may have damaged it by driving them a little too much too early. Break-in is a good thing. Call Polk tomorrow, I'm sure they'll take care of you. Good luck.
thanks for the reply. I have left a message with Polk CS already hope to hear from them tomorrow. cross my fingers hope I can get a replacement woofer.
