Pioneer SC-35 setup advice needed - Monitor 60/30/CS1/PSW505
shawne1979
shawne1979 Posts: 10
edited December 2011 in Electronics
First off, I would like to thanks those in the community who helped me choose what components to purchase for my new home theater system. You all had great advice and I really appreciate it. That being said, below is a list of my new setup, and I have some questions about how to set it up and get the best sound quality out of it.
Receiver: Pioneer SC-35
Fronts: Monitor 60's
Center: CS1
Rears: Monitor 30's
Sub: PSW505
I have everything hooked up, but the SC-35 receiver has so many options and I'm really confused. I've run the Full Auto MCACC, set all my speakers to small, and the subwoofer crossover to 80Hz, but I don't really like the way it all sounds. Below are some questions I had about how to setup the SC-35.
1) Should I bi-amp the monitor 60's? I only plan on running the system in 5.1 mode, so I have the outputs available to bi-amp the monitor 60's if I want. I just don't know if that will make any type of considerable difference.
2) When I run the MCACC it sets my subwoofer to -10dB lower than all my other speakers. The bass sounds really low when I listen to movies and music, so I was wondering if this is why. Why did it set the bass so low?
3) The MCACC setup separate equalizer settings for each individual speaker. Is this recommended, or should I equalize all the speakers to the same EQ?
4) Does anyone mess around with the Video Converter settings on their SC-35? I'm honestly not sure how I feel about the receiver doing video conversion for me. I have a really nice Panasonic Plasma TV and would think I would want it to handle all the video conversion. Anyone have any advice for this?
5) There is a setting for whether or not the subwoofer is THX certified. I set it to no since I don't think the PSW505 is THX certified. What does this setting do and how should I set it?
Those are the main questions I have for now. I might have missed something though. I know a lot of you own the SC-35 and if you have ANY advice for how to properly set it up, I would really appreciate it. I just want to get the best sound quality out of my system as I can.
Thanks guys!
Post edited by shawne1979 on
  • Sherardp
    Sherardp Posts: 8,038
    Walk away from it and start fresh. Read this.
    Work Flow:
    1) Set Reciever to MCAAC preset 1 (M1). Now Run Auto MCAAC with mic in you listening position (I taped the mic to the top of a two foot long shoe horn, and stuck the shoe horn inbetween the couch cushions, so the mic is right where my ears are during listening).
    2) Go into Manual Sp Setup and change the SP settings if neccessary(crossover to 100hz for me and speakers to small)
    3) Now re-run Auto MCAAC but select custom, and then select Keep SP settings. You will also be given the options to have MCAAC calibrate for symmetry, all ch adjust and front align. You may save each calibration to seperate presets or run just one of them, or run two of them. You will see these options after you select Keep Sp settings.
    4) Now you have an Auto MCAAC calibration(s) saved to M1 (or to multiple presets if you chose more than one EQ calibration type in previous step: symmetry, front align, and all ch adjust) (....note: you must select which preset you want Auto MCAAC to save calibration data to before you enter the audio setup menu.) Now go into Data Management
    > Data Copy and copy M1's data to as many other free presets as you like.
    5) Now go into Manual MCAAC--->EQ Professional
    >Reverb Measurement and get a reading on the the frequency response characteristics of your room. Be sure to select EQ OFF(standing waves not controlled for via MCAAC fliters) in the Reverb Measurement menu because you don't want the standing wave adjustements (EQ on) to be factored in to the room reverb measurments. Also make sure you haven't moved the mic.
    6) After test tones are done, go into Manual MCAAC--->EQ Professional
    >Reverb View , and you can analyze the frequency response of individual channels at various frequencies. Based upon that data, you would select the appropriate capture delay time for MCAAC to capture data during for the upcoming EQ calibration.
    Change that time frame under Manual MCAAC--->EQ Professional
    >Advanced EQ Setup to whatever you decide is the appropriate capture delay time ....(Pioneer recommends 30-50 ms, but they encourage you to analyze the data under reverb view first and refer to the advanced MCAAc software manual for analysis purposes). Note: the default capture delay time is than 80-160 ms.
    7) Change to the appropriate MCAAC preset before you run the new advanced EQ calibration with the new capture time. You choose which preset, but I would recommend a preset that is a carbon copy of an auto MCAAC calibration so that you can do an A-B comparison between auto EQ and advanced EQ. Go under Manual MCAAC--->EQ Professional
    >Advanced EQ Setup to start the advanced EQ calibration, and MCAAC should make a more accurate calibration since it will now capture sonic information sooner after the speakers output sound, and get a read on what the frequency response is of the speakers themselves, and not the speakers and all the reverb which accumulates as time passes. (Default capture time is 80-160 ms and thus collects more reverb and less true speaker reading)
    Now you should have an accurate calibration. Also, now you can easily compare the Auto MCAAC EQ effects that are stored in a preset with the advanced EQ effects in other presets while listening to content with a simple button press on the remote. You could also juice the base a few db in a preset, and also compare running the base a bit hot to a flat calibration that you have in other presets.
  • shawne1979
    Wow, thanks for the long setup description Sherardp. I will definitely give that a try as soon as I can and let you know the results.
    Can anyone help me with me other questions, like whether I should bi-amp the monitor 60's and what to do about the built in video converter?
  • Sherardp
    shawne1979 wrote: »
    Leave your 1080p sources untouched, and let the receiver power everything. No biamping/biwiring needed.
