Take the 320k vs 128k mp3 hearing test?
cnh
Here's a straightforward demo of why higher bit rates sound better. If you can't hear the difference I'd have your hearing checked.
I can barely hear a 14Khz tone (aging related loss) but I had "no" problem hearing the difference between these two mp3 files (would've been neat if they also had a lossless file to compare as well).
The interesting thing here is that you can hear this "even" on a fairly pedestrian system. My PC sound is essentially headphone out jack to an "old" Kenwood KR-5400 receiver powering a set of Realistic Minimus 7s. And the difference was immediately noticeable.
For you hard science boys and girls. This test works "blind" (since you don't know which option is 320 or 128).
Enjoy!
http://www.noiseaddicts.com/2009/03/mp3-sound-quality-test-128-320/
cnh
Enjoy!
cnh
Post edited by cnh on
That's pretty cool. I picked the right one with just my 2.1 Altec Lansings on my desktop.
(FYI for those taking it - you can switch between clip 1+2 realtime, it doesn't start over) Took me once time through to figure that out. lol65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I failed :redface:
I was able to hear the 15hz tone. Definitely older than 25I got static in my head
The reflected sound of everything -
I heard the difference with some cheap HK computer speakers. Definitely clearer in 320 than 128.
some say higher bit rate does not make a difference. Tell that to my hard drive, and my ears, neither will believe you. Yhe chapters are songs I ripped from dvda and converted to flac. I also have them in their native .mlp format, trying to find a codec or player that can play them.
On my laptop speakers I couldn't hear the difference in the bit rate test, and could only hear up to 15khz. I was hoping it was simply the laptop speakers, but the dogs ears perked up on 22khz. I'm 42. I wonder if these common speaker upgrades (tweeters, xo's, etc) still offer value to me or is it wasted money?Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
Picked the correct one with my HK computer speakers! These are cheapies but they sound surprisingly good. The files were pretty close I thought. My first immediate impression was the correct one, but then I listened to each one twice more and stuck with the first impression.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
JimMueller wrote: »On my laptop speakers I couldn't hear the difference in the bit rate test, and could only hear up to 15khz. I was hoping it was simply the laptop speakers, but the dogs ears perked up on 22khz. I'm 42. I wonder if these common speaker upgrades (tweeters, xo's, etc) still offer value to me or is it wasted money?
The tweeters in my SDA's crossover at 2.5Khz, so I think you would still benefit from upgrading. -
I agree. There is not a lot of musical information above your hearing range (15Khz). I'm older and hence the lower frequency range but even I can hear significant differences between various pieces of equipment and speakers. Plus having an expanded frequency range in your equipment actually helps clean up the sounds you actually can hear--and some argue that certain cues are received from information we can't hear (theoretically). Upgrades do not require that you hear like a 15 year old.
My daughter is 14 and can hear the 21Khz test tones. I hear 14Khz (barely) but I don't think that my appreciation of good sources is "less" than hers--"experience" is also a factor.
The same can be said for intelligence. It peaks early and then begins a slow decline, however, experience, knowledge, education, and age compensate incredibly so that a Professor in his/her 50s is not seen as a senescent dolt but a leader in his or her field, an "authority" whose opinions are eagerly sought.
If you check that site you'll see that hearing declines pretty "early" in life. You've already lost some upper range by 30 (on the average of course--there are exceptional cases).
Besides, just like with anything else PC rated...it's not just the numbers that tell the story. The 'quality' of an mp3 largely boils down to the algorithm of the encoding software and how the user takes advantage of said software. This 'test' really doesn't really do much to highlight the difference between 128 and 320, but I digress..
Don't disagree with any of the above. But would you not say that if one is using the same encoding for both rates and one can hear a difference that that "is" something that you could probably reproduce with any other "better" algorithm encoding in the same way, i.e., the encoding at 128 vs. 320. This is nothing more than a crude test of course, no one is claiming much more than that?
Digressions are encouraged. By all means extend the discussion, no reason why we can't step up the discourse with more refined and informed data.
I could only hear up to 15kHz as well, but I'm only 32. I also used a third party sound generator to confirm. However, I've never had great hearing, even as a child, so I'm not surprised.JimMueller wrote: »On my laptop speakers I couldn't hear the difference in the bit rate test, and could only hear up to 15khz. I was hoping it was simply the laptop speakers, but the dogs ears perked up on 22khz. I'm 42. I wonder if these common speaker upgrades (tweeters, xo's, etc) still offer value to me or is it wasted money?
As for the 128kbps vs 320kbps sample, yes I could tell the difference, including on some mid-range Creative computer speakers. -
320kbps with Beats FTW! :cheesygrin:65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
I guess the hereditary hearing loss and ear surgeries are showing their true colors at a mere 27.
Can only do 14Hz and failed the AB comparison....but i did ace the "Which sine wav is louder" section. I may not be able to hear low and differences but i can still tell you what is louder than the other....oh and if they are "Real" or "Fake"
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
That's an interesting and fun link, and thanks for sharing!
The 320k sounded better to me via 8$ Sony headphones, but the difference was not quite "night and day".
Assuming the test is not like this terrible BestBuy "megapixel demo", it is quite convincing
I failed the test - maybe I need better cables ??
???? Most people are getting it wrong????You selected Clip# 1 …Congratulations!
Clip #1 is encoded at 320kbps (36613 votes)
Clip #2 is encoded at 128kbps (40520 votes) -
mdaudioguy wrote: »???? Most people are getting it wrong????
Wow...looks like Zero called that one! I suspect people are not listening closely. This reminds me of Darqueknight's threads on how he measures or educates the listener for "what" to listen for. Then again, there's also the question of the equipment used. But hey, if we were "normal" we wouldn't be here (hear?) lol
The question asks "which one sounds better". This question seems to presume that everyone will like the 320 kbps file better. But we already know that's not correct. A test was done where a bunch of college-aged people were asked to listen to 128 kbps mp3s through cheap ear buds and 320 kbps files through "audiophile" headphones. The 128 kbps files through cheap ear buds won by a large margin, because *that's what they were used to*.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I picked out the correct one i think you can tell the biggest difference in the cymbals and how they sound.Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
ugh. :rolleyes:2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
Yep, cymbals are one of the first and easiest places to pick up on the harshness in the lower quality mp3. Actually, with good enough equipment (ears included) any mp3. The cymbals sound tinny and not smooth. Also, the high end on the vocals and instruments don't sound as good. The same goes for a CD copied multiple times. It's a very similar sound. I am not trying to start this debate again, but if people can hear the lower quality mp3 harshness, you should be able to hear a CD copied a number of times and the result on the high frequencies.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
My son at 16 can hear the 21 kHz tone. I can only hear to 14 kHz but I'm 50. We both picked the 320 sound file.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
WOW! you just love to argue, Sad really...
Maybe they were used to it because that is what itunes and those other music services offer. And that listening test you are talking about was totally screwed up. The ear buds I use (Skullcandy) can dig deeper and clearer than the old Audiophile Sennheisers I used to use.
Now if they had run the 320k through the ear buds the kids would have heard a difference. -
Agreed. There were two variables and no control, which makes for a useless and invalid study.And that listening test you are talking about was totally screwed up.
Right. However, I think what quadzilla was trying to say was less about whether there was a difference and more about preference. Assuming they ran the test with 128kbps and 320kbps on the same headphones, and the difference was heard, it's possible they may still have preferred the sound of the 128kbps mp3. Personally I don't understand why anyone would, but different people have different preferences.Now if they had run the 320k through the ear buds the kids would have heard a difference. -
Who's the one arguing, Joe?
quad is only submitting a correlative study. You have to realize the humor in your statement that "that listening test you are talking about was totally screwed up" (A test presumably done on a larger population than one) because your skullcandy earbuds wer better than the the old Sennheiser's. You're making quad's point for him in your ignorance. He is saying that the test results are a function of preference (or perception), not performance. Which is exactly what you are saying, although you don't know it. this is what we call irony.
For your reference, as an owner of 5 or 6 pairs of skullcandy headphones (i always find myself at airports or skilifts without a pair and have to buy new ones), skullcandy are bottom of the pile along with beats and countless others in terms of musical reproduction, but theyre enjoyable with their bloated bass and relaxed highs. Now that I've said that, does it make it true? No, but a consensus can make it relevant. Until then, it's just one man's opinion
design is where science and art break even. -
I am also saying that if you feed them crap they will learn to like it. And after I posted I realized I was the one arguing. Oops,
Also as far as the ear buds vs over the ears go, I prefer buds personally. Just for the fact that they really filter out the outside sounds more than anything. I don't think they sound better per say. -
Which is all I was saying. People get used to listening to certain things, and that becomes their preference. I can't stand 128 kbps over cheap earbuds, but that's just me.Turntable: Empire 208
Arm: Rega 300
Wow... even the most basic of understandings eludes you. Sad, really. I wasn't arguing with anything. I simply made a statement that the article asked which one sounded better, and someone in this thread seemed surprised that over half the people responding "got it wrong". But since it's a subjective test, there is no "wrong". It's a matter of preference. Then I cited a study that proves that what's "better" isn't necessarily what people always prefer. If you have a problem with facts, then feel free to put me on ignore. In fact, I would implore you to do so.
Nice, now I am an idiot. Thanks for that. Have a nice day. -
Im with you there. If I'm anywhere but home, the isolation of buds is fantastic. At home in a quiet environment, for my ears, nothing beats an open-back set of cans like my audio technicas or grados.design is where science and art break even.
