How do you watch TV?
pixiedave
Analogue Cable>Sony DVD-RW>48khz pcm digital sig>HT AMP
I usually watch in Cinema A or B.
Comments suggestions. How do you process your tv audioo?
You never blow your trip forever! < Daevid Allen
Post edited by pixiedave on
digital coax out of the cable box into the digital input on the receiver
dts neo:6 for stereo channels, dolby digital for digital channels. -
Completely nude.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
with my eyes opened
Sitting down
Eh, I guess I'll answer it seriously. I just hooked up the cable to my receiver. I have component cables running from the VCR to the receiver. No digital cable for us, so we get no digital channels or signals. I have tried each of the surround settings (DTS & PL2, cinema and music) and have found PL2 cinema to be the best sounding. Second to that would be DTS Neo Cinema. I would say PL2 is a significant contributor to enjoying TV now. It either makes little difference, or a pretty good surround simulation. I would say it has yet to distract from the normal stereo sound from a show. The thing I enjoy most is having a subwoofer now to go with TV. I have yet to try surround with broadcast sports, but I imagine it might be fairly interesting.
Digital Coax from Cable box
Coax cable from floor to vcr, then from vcr coax to tv........
nothing speshil- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
With an ice cold Sierra Nevada.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Watch HDTV via off-air HDTV tuner. Sony VVEGA (XBR400 36" flat) is HDTV ready. The TV has six inputs two which are 16:9 ratio. TV also great for watching DVDs.
TV? That's that picture thingy that makes people go stupid, right? Give me music, it sharpens the mind.
President of Club Polk -
Direct TV coax >VCR>TV(RF input only). DVD>VCR(line input1) with TV on CH3. Till I uprgrade my TV that is the only way to enjoy all my HT.
SAT audio toslink connection to receiver and DVD digital coax to receiver.
90% of the time I use DDPLII movie mode for broadcast TV and downloaded movies. I use Cinema mode B for some DVDs. It depends on what my receiver gets for a signal. -
My system is very basic:
1. Dish Network satelite box fed through a Monster Cable THX series s-video cable (for picture) and Monster Cable toslink fiber optic (for sound) into the video "2" input of an old Panasonic 32."
2. My video "1" input is fed from a Sony DVP through Monster Cable THX series component video cables for picture and I am running a Monster Cable toslink for sound.
RockyRocky Bennett -
Direct TV Zenith 520 to component Vidio to Sony 57" and TOSLink from Zenith to AA DTI to my h/k520 AVR. "and now you now the rest of the story."
HBomb***WAREMTAE*** -
Just an observation: I am really surprised at how many people state they use coax somehwere in their system. I barely remember coax, I have not used it in my video system since 1986. I remeber the very last time I used a coax and the time I first switched to a composite video cable, it was Sept. 1986, since then I have never used coax again.
In my case I was referring to the audio path, which is what I thought the question was ... not the video path.
The digital cable box has o/p's for digital coax which would go direct to preamp/receiver for sound processing.
