Media player for the PC (XBMC -Jriver- foobar - media monkey)
thejck
thejck Posts: 849
edited December 2011 in 2 Channel Audio
Has anyone tried these different players or done a comparison between a few to see if one sounds better than the other as far as music is concerned?
I currently use foobar with the WASAPI driver to achieve bit perfect output to my DAC but I am thinking about switching to something that has a better music collection DB and browse feature aka XBMC where I can browse from across the room plus maybe control with a remote or my Android.
I currently can control foorbar with my android and I have played with XBMC but I wanted to see if its worth the money to try jriver or MM.
any thoughts?
Does any sound better if they are all using the WASAPI driver or do they impart some of their own coloring on the music?
Post edited by thejck on
    heiney9 Posts: 25,430
    Media Monkey is my standard and works flawlessly and has a plethora of features.
  • Fongolio
    Fongolio Posts: 3,516
    I've been using J River for about a year. They keep adding new features with updates and it will upconvert audio if so desired. Between J River and foobar I'm happy.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • thejck
    thejck Posts: 849
    Why would you want to upconvert audio? Doesnt that defeat the purpose of trying to achive bit-perfect?
    Between the 2 players have you heard any Difference?
    @H9 Is MM only for audio?
    thejck wrote: »
    As far as I know. I've been using it for about 3 years. If they have added video capabilities I am not aware, I don't really follow all the breaking news in regards to MM.
    http://www.mediamonkey.com/
    It now appears is may have some video capability. You'll have to poke around the site
    EndersShadow Posts: 17,703
    XMBC works decently for most video files, and also streams FLAC. I have installed XMBC but havent play with it extensively.
    I use Media Monkey on both my desktop to stream to my office setup, and also on my laptop (via HDMI OUT) to my Integra downstairs. I have taken the laptop with me elsewhere (dcmartinpc's house) for demo use and it worked great there with media monkey (although we used a HRT media streamer).
  • kappclark
    kappclark Posts: 136
    heiney9 wrote: »
    Mediamonkey is rock solid...I have the library on an Ubuntu laptop, but library is less than 50GB, so a walk in the park for M.M...
    Just curious - does it use MS SQL ?
    ** Bill Clark Windham, VT **
    Toolfan66 Posts: 18,016
    J River for me with no problems..
    Fongolio wrote: »
    Upconvert?? Hmmm I don't recall it doing this..
  • thejck
    thejck Posts: 849
    Larry is that you? What happened to your name?
  • strider
    strider Posts: 2,568
    Download the J Rivers demo, it's free and has all the features that the pay version has, IIRC. I used it for a bit, went back to Foobar, will probably go back to J Rivers when I've got a dedicated HTPC up and running.
    Wristwatch--->Crisco
  • coolsax
    coolsax Posts: 1,826
    I use Media Monkey.. really like it a lot... very easy to use
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • inspiredsports
    inspiredsports Posts: 5,502
    Post #11 wenzizi reported as spam for removal
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Tbone289
    Tbone289 Posts: 661
    I'm still using Winamp Pro with the Maiko WASAPI output plugin. I just really like how the media library works in Winamp, and I haven't found anything that matches it, even with numerous modifications. Foobar is great for conversions, but I've never been able to get the library to work just so.
    I've tried J. River and, while I like it, I think it's a bit bloated with unnecessary bells and whistles. I prefer to keep my music and video media players simple and separate.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Face
    Face Posts: 14,340
    J. River, anything else is a toy.
  • FTGV
    FTGV Posts: 3,650
    Face wrote: »
    My prefered flavour of KoolAid as well.
  • thejck
    thejck Posts: 849
    has anyone with better ears than mine actually tried to see if there is an audible difference between foobar and jriver when using wasapi?
    Also I presume from what I have read is that using WASAPI vs ASIO puts you miles ahead. Anyone tested between those 2?
    Media Monkey is hardly a toy :rolleyes:
  • drselect
    drselect Posts: 664
    thejck wrote: »
    I recently upgraded to MM v4 which allows you to use either WASAPI or ASIO. I am still using ASIO but may try to running a test to compare the two Also I think you asked earlier about video, MM v4 does have video capabilities but I have not used them yet.
  • thejck
    thejck Posts: 849
    i have been perfectly happy with using foobar all these years. Now I discovered the LIbrary mode that xbmc has along with the android remote to browse the lib and I want.
    I know jriver has this as well. Plus I wont have to use a seperate player for video and audio as i do currently. I have downloaded jriver and am going to give it a try. I might give Media monkey a shot to see if I like that interface better.
  • Fongolio
    Toolfan66 wrote: »
    Go into DSP studio where you can change sampling rate and bit depth. Sample as high as 192 khz and bit depth to a staggering 64 if desired. J River runs internally at 64 bit already.
    As for why someone would want to....many of the very high end DAC's have options for upconverting 44,100/16 bit to higher resolutions. Results vary with some sounding better, some sounding worse, but it is for sure no longer a bit perfect file you're listening to once upconverted.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • thejck
    thejck Posts: 849
    Woudnt that defeat the purpose. After all the direct show driver "upconverts" to 48 that sounds like crap. Why would this be any better?
    Fongolio wrote: »
  • thejck
    thejck Posts: 849
    both jriver and xbmc were doing this last night. After I scanned some music to the library, it took one album "singers and songwriters" that had disc A and B and split it up so that each individual song in those disk's showed up as seperate albums.
    Anybody seen this before?
  • thejck
    thejck Posts: 849
    is there a way to organize the music without having to use id3 tags on the files itself? I have all my music in flac and i dont really want to use tags to alter the flac files.
    thejck wrote: »
    No
    and you have a misconception about ID3 tags. They DO NOT alter the music or file at all. They are embedded in the metadata and there is no way to manage the digital files without proper ID3 tags.
    Why don't you want to use ID3 tags? What harm do you think it's doing by doing so?
  • thejck
    thejck Posts: 849
    heiney9 wrote: »
    the EAC guide that I followed when backing up the CD's stated that adding the ID3 tags to the flac file make it so that they are never restorable in case the need should ever arise where I would loose the CD and need to restore it from the flac files.
  • PrazVT
    PrazVT Posts: 1,607
    Uh no. ID3 tags don't have any impact on converting the audio back to wav and then burning it to CD.
    I've been using J River myself. WASAPI + playback in RAM -> W4S DAC-1 sounds great. Once I configured all the video / audio codecs and turned on GPU support, I've found J River to a great player for my 1080p / AC3 .m2ts movies.
    It may be bloated with features, but it's a fast program. No slowdowns or anything on my machine.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    thejck wrote: »
    I don't understand what that means. I've made lots of cd's from FLAC files before w/o any issues. Maybe you could provide a link so it's in some sort of context.
  • kappclark
    heiney9 wrote: »
    I am very pleased with Media Monkey - very fast lookups..
