How powerful an AVR needed for rti a3 / csi a6
hookem12
hookem12 Posts: 22
edited January 2012 in Speakers
What kind of wattage avr would this setup need?
How would a denon 2112 fair?
thanks
Post edited by hookem12 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited December 2011
    How big of a room and what are your listening habits....mid volume for jazz or acoustic, or do you like to pretend you are at a Who concert? :smile:
    When I had RTiA3s and CSi3 I could run those in a medium sized room to "turn that down" loud from my wife using my Yamaha RX-V1800
  • Lietuvis91
    Lietuvis91 Posts: 909
    That Denon claims to have discrete channels, meaning all the channels should put out the rated 90w/ch. Looks like a nice avr, should do fine for those speakers. It does not have pre-outs, so you will not be able to add an amp if you upgrade your speakers. Something to think about.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • nguyendot
    nguyendot Posts: 3,594
    It would power it fine, though I doubt it would actually hit 90w/channel all channels driven. Discrete or not, the power supply is still shared.
    Main Surround -
  • hookem12
    hookem12 Posts: 22
    its what I'm running right now and the denon folks said it wasn't powerful enough.
    because i had to turn it up to -9ish db to have decent volume
    I tinkered around and turned off samsung tv's anynet and now -40 db is about what -9 db was sounding like
  • Slaine777
    Slaine777 Posts: 78
    edited January 2012
    I am using a HK AVR-3600 to power RTI A3 fronts with a CSI A6 center.
