Anyone use a sub with 2-channel?
I'm pretty sold on the idea. I'm imagining some Linkin Park power chords thru an SVS.....:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
When you're adjusting the Phase, what are you listening for to get optimum sound integration?
I'm running about 20 FR sweeps via my test rig. I go in 10 degree increments. Easy and fast with the QuickSweep function on TrueRTA. 110 degrees is perfect in my rooom; the curve just flattened out like magic."What we do in life echoes in eternity"
SVS -
Doc,
What kind of tools are their for measuring stuff like this outside of using an SPL meter and without laying out a bunch of cash ?
Is this what you are referring to ? http://www.trueaudio.com/rta_abt1.htm ... What other equipment is needed ? A certain kind of mic ? etc. -
You need:
1) The software ($100).
2) A measurement mic ($50).
3) A mic pre-amp ($70).
4) An audiophile grade PC sound card ($100).
5) Professional FR calibration of the pre-amp and mic ($50).
6) A sound level calibrator for the mic ($350).
6) A handful of interconnects and adapters ($50).
7) A firm grasp on manipulating the log10 dB scale and calculating THD.
8) A boatload of patience for a very steep learning curve.
I was fortunate enough to already have a sound level calibrator, so I didn't pay for that part. But if you are just getting started, you'll need to buy one. It can be used to calibrate SPL meters and mics - it generates a test tone at a specific SPL when the nose of the mic is placed into the receiver cup of the calibrator.
Doc"What we do in life echoes in eternity"
SVS -
Thanks for the info ...
Although I'm sure this methodology is what's needed to be totally accurate, it appears to be more than I have the patience or need for.
Short of that is it just an Avia disk and a SPL meter ? or are there other viable methods in between some where. -
the cheapest route is a CD with test tones and an SPL meter, it just takes a LONG time to run through them and then plot graph of your results. It's a pain, but with some time spent it can be very rewarding...
here are some test tones to download and burn to a CD
http://www.snapbug.ws/sinewaves/Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Make sure to use the correction factors for the RS meter. They aren't exact, but they are far better than not using them.
Also, the Behringer ECM8000 mic I use is a steal for $50 - nothing else comes close as a measurement mic for the price. But aside from that, a pro grade mic (like LinearX) with say 160 SPL capability @ 2% THD will set you back about $400.
Add auto THD capability from software like SpectraPlus, and you're looking at $800 vice $100.
And if you go full bore pro grade test rig all the way - count on $5000+."What we do in life echoes in eternity"
SVS
