dual sub set up.
Here's a question for ya! If I were to go from 1 svs 20-39+ to 2, would I place them at equal distances from the left and right mains or group them both together in the same "sweet spot"? also depending on which placement you think is better how would I set the phases for each? :confused:
P.S. Home Theater is 12X20 and has an independent floor.
Reciever - Onkyo TX 797 (100X6)
Mains - RTi8's (Bi-Wire)
Center - CSi5 (Bi-Wire)
Surrounds - FXi5's
Subwoofer - SVS 20-39+
Moniter - Sony KP-57HW40
DVD #1 - Sony - DVP-985V (400 Disc)
DVD #2 - Panasonic - DVD CP72
CD - Sony - CDP-CX450 (400 Disc)
Sat - Sony SAT - W60 (DirecTv)
VHS - Sony - SLV-N88
Post edited by sleepyweasle on
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2004
    Place side by side. Same phase.
    Regards,
    PolkThug
  • gatemplin
    gatemplin Posts: 1,595
    edited April 2004
    You cant stack an SVS cylinder.
    I think the simplest solution is to calibrate for 1 sub, including phase and find the sweet spot. Then place the other beside the first and use the same settings except recalibrate the gains.
    EDIT: To adjust the phase, plot a frequency response graph using test tones. Choose various phase settings and stick with the flattest curve. I know for myself and Dr.Spec 180 degrees worked out best.
    I have used up to 3 subs in different locations, and found that co-locationg was always best but YMMV.
    Graham
  • faster100
    faster100 Posts: 6,124
    edited April 2004
    cost effectiveness... in mind.. sell the 20-39 and get a pb2 + or isd.. if you put them in the same corner they will be close to the size of a pb2
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2004
    am i right in saying that the 2 subs have to be the same, or is using 2 different subs a possibility. i've seen a few people using 2 different subs on the home theater forum, but i dont see it much here. is it frowned upon?
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • sleepyweasle
    sleepyweasle Posts: 20
    edited April 2004
    Ohski I don't know? I suppose I am using the same logic that says: you wouldn't use 2 different mains??? maybe some one can chime in here and settle this for us..Is it o.k. to use 2 different style subs in the same set-up.
    Surrounds - FXi5's
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    calibrate one sub, test it....walk around your room and find the spot that has the least amount of bass, place ur second sub there.
    i heard it works, never tried it tho.
  • ohskigod
    edited April 2004
    might try that, i have a very large room, living room and dining room are combined into one large room. ah, WTF, what can it hurt?
