dual sub set up.
sleepyweasle
Here's a question for ya! If I were to go from 1 svs 20-39+ to 2, would I place them at equal distances from the left and right mains or group them both together in the same "sweet spot"? also depending on which placement you think is better how would I set the phases for each?
P.S. Home Theater is 12X20 and has an independent floor.
Reciever - Onkyo TX 797 (100X6)
Mains - RTi8's (Bi-Wire)
Center - CSi5 (Bi-Wire)
Surrounds - FXi5's
Subwoofer - SVS 20-39+
Moniter - Sony KP-57HW40
DVD #1 - Sony - DVP-985V (400 Disc)
DVD #2 - Panasonic - DVD CP72
CD - Sony - CDP-CX450 (400 Disc)
Sat - Sony SAT - W60 (DirecTv)
VHS - Sony - SLV-N88
Surrounds - FXi5's
Post edited by sleepyweasle on
You cant stack an SVS cylinder.
I think the simplest solution is to calibrate for 1 sub, including phase and find the sweet spot. Then place the other beside the first and use the same settings except recalibrate the gains.
EDIT: To adjust the phase, plot a frequency response graph using test tones. Choose various phase settings and stick with the flattest curve. I know for myself and Dr.Spec 180 degrees worked out best.
I have used up to 3 subs in different locations, and found that co-locationg was always best but YMMV.Graham -
cost effectiveness... in mind.. sell the 20-39 and get a pb2 + or isd.. if you put them in the same corner they will be close to the size of a pb2MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
am i right in saying that the 2 subs have to be the same, or is using 2 different subs a possibility. i've seen a few people using 2 different subs on the home theater forum, but i dont see it much here. is it frowned upon?Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Ohski I don't know? I suppose I am using the same logic that says: you wouldn't use 2 different mains??? maybe some one can chime in here and settle this for us..Is it o.k. to use 2 different style subs in the same set-up.Reciever - Onkyo TX 797 (100X6)
Surrounds - FXi5's
VHS - Sony - SLV-N88 -
calibrate one sub, test it....walk around your room and find the spot that has the least amount of bass, place ur second sub there.
i heard it works, never tried it tho. -
might try that, i have a very large room, living room and dining room are combined into one large room. ah, WTF, what can it hurt?Living Room 2 Channel -
