Extending Poly Capacitor Leads - What Wire?
PreCd
PreCd Posts: 786
edited December 2011 in DIY, Mods & Tweaks
I need to extend the leads on my capacitors for the upgrade to my SDA2B crossovers. What wire should I use?
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
    Toolfan66 Posts: 18,162
    If your replacing all the caps then use the other pieces of leads you snip off the other caps that's what I have done..
    F1nut Posts: 51,953
    Like Larry says....if the cut offs are long enough. Other than that, I use insulated 18 gauge solid core copper wire.
    VR3 Posts: 29,537
    I have used DH Labs 18 guage - I believe it is something like T-10X or something along those lines. Usually comes twisted for long runs...
  • PreCd
    PreCd Posts: 786
    I was thinking of using some good copper wire that is the same size such as a 18awg copper wire.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    F1nut Posts: 51,953
    Just don't use bare copper wire as it will oxidize.
  • dorokusai
    dorokusai Posts: 25,576
    You could just spray the bare wire with a clear laquer or paint. There's no reason not to use what you have handy.
  • PreCd
    PreCd Posts: 786
    Thanks everyone for your advice. I ended up getting some 18awg wire from an electrician friend. It came from some demoed ballast from fluorescent lights. It was solid and insulated and when I put the iron to it for tinning it conducted the heat very well and fast. Good stuff.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
