Speakers Calibration
salfand
salfand Posts: 11
edited December 2011 in Speakers
Hi Guys,
Yesterday I got my new Polk Audio FXi-A4 which complete my set:
Front: RTi-A7
Center CSi-A6
Rear: FXi-A4
Receiver: Yamaha Rx-v2067
I don't have sub.
After connecton the new rear speakers I run auto calibration using YAPO.
After the calibration I feel that the bass and the sound (Specially on stereo) are not so good as it was before calibration.
Anyone can assist here?
I notice that the rear speakers setup with 90HZ. Is that ok?
Thanks,
Shmulik.
Post edited by salfand on
    tonyb Posts: 33,072
    Don't take the calibration as gospel. Go into the receivers menu and go to speaker levels. Start at 0 and go up or down from there. The sub level probably need to be around +3 to start and you can adjust up or down manualy.
  • MADGSF
    MADGSF Posts: 603
    I would make sure the sub is set off/no since you don't have one. Also make sure the front R/L are set to large/full so all the bass is sent to the front R/L speakers. Not sure how Yamaha shows this in their menu you just want to make sure the low frequencies are sent to the A7's since there is no subwoofer.
    I would set the crossover for the rear speakers to 80Hz and if you can set the center independantly 60Hz. Test and adjust from there as needed.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
