Power Amp: Emotiva or Marantz
Mongo
Mongo Posts: 52
edited November 2011 in Electronics
Hi all,
Well, after some weeks of research on a power amp, it looks like I am getting close to the point of pulling the trigger.
Now I am in between two choices:
1) Marantz MM7055 + MM7025 with my mains RTiA9`s bi-amped.
Pros: I'd stick to the "Marantz quality", as my AVR is a SR6006, and plenty of power to my mains (140 W + 140 W)
Cons: expensive, and these MM series look very light, I expect amps to be heavy
2) Emo XPA-5
Pros: cheaper, it looks more robust than the MM`s;
Cons: no "Marantz" tonality, but I don`t know up to which point the amp would affect the sound.
Question: would the 200 wpc of the Emo possibly damage my 150 W rated FXiA6 ?
Thanks a lot,
Mongo
Receiver: Marantz - SR6006
Main: RTi A9's (powered by 2 Emotiva XPA-1`s, bi-amp)
Center: CSi A6
Surrounds: RTiA5's
(center and surrounds powered by Emotiva XPA-5)
Subwoofer: Infinity PS312
TV Sharp 70"
Post edited by Mongo on
  • codyc1ark
    codyc1ark Posts: 2,537
    I can't comment on the sound of either amp, only that emo isnt highly touted here. I can however tell you that you'll be fine running that kind of power. As long as it's clean power, I doubt you'll ever drive it at it's max, so you'll be fine.
  • Face
    Face Posts: 14,340
    Here's a multichannel amp that sounds good and would cost as much as your Marantz combo. http://www.wyred4sound.com/webapps/p/74030/117839/339143
    I'm currently using it with a Marantz AV-7005 for HT and gaming, and a Wyred 4 Sound preamp and DAC-2 for music, it does a great job all around.
    F1nut Posts: 51,729
    Unless you use an external active crossover you are not bi-amping regardless of what you may have heard or read.
    That point would be the first watt and if that first watt sucks, why bother.
  • zane77
    zane77 Posts: 1,696
    Mongo, I know a few of the others on this site don't care for Emotiva but I have the XPA-5 and love it, maybe my tastes aren't as refined as some of the others or maybe I listened to too much loud music when I was younger and it messed with my hearing (we all loose some frequencies as we age anyway). You can always order the XPA-5 and give it a try for 30 days, they pay for shipping both ways if you don't like it.
    Two Channel
  • Mongo
    Mongo Posts: 52
    Sure, the only advantage would be to feed the double power (140 W + 140 W) into the "hungry" RTiA9`s.
    Thanks to everybody that have been replying,
    Mongo
    Center: CSi A6
    Surrounds: RTiA5's
    TV Sharp 70"
  • Mongo
    Mongo Posts: 52
    zane77 wrote: »
    Thanks, I am very tempted to give it a try;
    Mongo
    Center: CSi A6
    Surrounds: RTiA5's
    TV Sharp 70"
  • Mongo
    Mongo Posts: 52
    Please, considering the the FXiA6 is rated 150 W, and the XPA-5 feeds 200 watts, am I in the risk of **** them up ?
    Center: CSi A6
    Surrounds: RTiA5's
    TV Sharp 70"
  • dorokusai
    dorokusai Posts: 25,576
    Mongo wrote: »
    No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act.
    Marantz or Emotiva? Who cares, buy what fits your pocket unless you want to get much cooler and much better in the long run and consider Faces' reco. EMO will get zero retail back, keep that in mind and the Marantz just won't make anyone care for the most part. Their amps don't intimidate ppl and vintage have the scores for this brand unless you're talking CDP's. The W4S suggestion has solid buzz and will get he most payback if you ditch it within a year. Learn your own way I guess....school is out.
    F1nut Posts: 51,729
    Mongo wrote: »
    I suggest you research what bi-amping really is because your idea isn't it.
  • FTGV
    FTGV Posts: 3,650
    Mongo wrote: »
    Correct the only advantage of passive bi amping is the potential for a few extra DB of power headroom.
    VR3 Posts: 29,419
    dorokusai wrote: »
    Ah, that made the sig
  • dorokusai
    I'd like to thank the Arts Academy...my **** and the dark lord Satan. Thank you....and I'll be sleeping on the couch if you need me. Peace!
  • Mongo
    Mongo Posts: 52
    FTGV wrote: »
    Thanks for the positive words,
    To the other guy, I certainly know exactly what I'll possibly be doing...
    Mongo
    Center: CSi A6
    Surrounds: RTiA5's
    TV Sharp 70"
  • FTGV
    FTGV Posts: 3,650
    Well don't take my words as a strong endorsement ,as IMO the benifit of a few extra DB will be mildly perceptable at best.
  • dorokusai
    Negligible is a better word. Your efforts are best served elsewhere if this is a driving factor for you.
  • cfrizz
    cfrizz Posts: 13,415
    You will be fine with that much power. The speakers will only take what they need to operate to their full potential. What's important is to make sure that the power is there for them to draw on when needed. It's when the power isn't there that trouble arises.
    Mongo wrote: »
  • Face
    Face Posts: 14,340
    cfrizz wrote: »
    That's not really how speakers work.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    zane77 wrote: »
    They will refund your purchase price. The customer is responsible for paying for the return shipping.
    dorokusai wrote: »
    Believe it or not, the resale market for used Emo amps is pretty good, IMO. I sold mine for 90% of what I paid for them, after having them for a little more than a year, and the buyers covered shipping!
  • cfrizz
    Oh good grief, in most normal situations it is. It only gets funky if you go crazy with the volume.
    Face wrote: »
  • cstmar01
    cstmar01 Posts: 4,424
    the Emo won't hurt your speakers.
    IMO there are also good options out there on the used market for amps as well. Just because it's new doesn't make it better than a used one. Watts are not everything.
    If you have to get new then also check out outlaw to see what they got.
    If you want some more ideas check out Audiogon and look up: Rotel, Adcom, Parasound, Anthem, Wyred for Sound, etc as if your looking in the 800-1K range there are a lot out there.
  • FTGV
    FTGV Posts: 3,650
    cfrizz wrote: »
    Cool, good to know.Thanks.
