5.25 to 6.5 how do i make it happen?
ipartywhenuhurt
Have sr6500 and I need to fit them in 5-1/4 any ideas on custom build adapters etc?
Post edited by ipartywhenuhurt on
Depends on how much space you got in your doors, between door skin and (plastic) door panel and how your grill is/fits/installs.
I'd look for these anwsers in your car-specific forum.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
I have built them with 2 layers of plywood its a 2 piece setup that screws down in the 5" holes and further up it has a mount for the 6" driver
How are you on depth? Are you completely against trimming?
If you have the depth,m a jig saw will make it work. I have put 6x9s in the front doors of a Saturn, and have put 10" woofers in the doors of a F150, and needed nothing more than a jigsaw to make the hole.
