SDA 1C Upgrade Complete (with a few pictures)
Marty913
Marty913 Posts: 760
edited November 2011 in Vintage Speakers
I recently completed a couple of upgrades on my SDA 1C?s. Knowing how much you all like pictures (and bright, shiny objects in general), I thought sharing a few might be in order.
Many thanks go out to the forum in general for all the tips. A special thanks to Tony (gimpod) for his great XO boards, and for his advice & moral support with a few self-induced upgrade problems. Also, thanks to Larry (TOOLFORLIFEFAN) for his great rings.
I had already swapped out the SL2000 tweeters for RD0194?s a couple months ago so the recent upgrades included rebuilt crossovers, Larry?s rings, spikes, and new binding and I/C posts.
The parts used were a little different than most of the upgrades but I wanted to keep the cost reasonable, maintain overall quality, and draw from my SDA2 upgrade experience of a couple years ago. The caps were Dayton 1% and Solen 5%. Resistors were all Mills and binding / IC posts were some Dayton?s I already had and Vampires for the IC. Spikes were from SupercellAudio.
It?s earlier in the listening phase but the upgrade results are amazing. Others have mentioned the bass improvements but I think the real winner may be the mid-range clarity and the over SDA effect. I suppose the downside to doing several major things at once is that it prevents you from pinning down the exact effect of each upgrade. I can definitely live with that.
For those non-electrical types contemplating the upgrades, I have a MS Word document with my notes / tips. It won?t do the veterans much good so I won?t bore you with it here but it?s available. There might be something in it that will help someone out. Just PM or email me.
Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
Post edited by Marty913 on
  • thsmith
    thsmith Posts: 6,082
    Very nice !
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Nice work, what made you go with dayton over sonic caps? Just wondering.
  • george daniel
    george daniel Posts: 12,096
    nice work indeed.
  • Marty913
    Marty913 Posts: 760
    Oldfatdogs wrote: »
    I know Sonicap's are well thought of by the forum members but they are more than twice the price, have a higher rated variation (5% vs 1%), and lower VDC rating (200 vs 250). I couldn't find any objective evidence they were better.
    TT = Audio Technica
  • Oldfatdogs
    Only reason I ask is I'm going to order parts for a monitor 7b upgrade. Some of the guys used Dayton and Solen,but now are using Sonicap's. Thanks Dan
  • gimpod
    gimpod Posts: 1,793
    Very nice job, Very clean the way it should be.
    Toolfan66 Posts: 18,140
    Very nice work!!! Your work will be rewarding..
  • dpowell
    dpowell Posts: 3,081
    Congrats! You're going to love it once those caps break in. Some day you must try them on a tube amp...
  • drumminman
    drumminman Posts: 3,396
    Nice pics and good job!
    heiney9 Posts: 25,488
    Very nice job!!! I hope you can live with the Solen's, the Clarity PX would have been a smoother, less fatiguing choice for about the same $$$ or less. I tried Solen's and just didn't like their sonic signature which is forward and a tad brittle compared to the Clarity PX. The Clarity has slightly better imaging properties as well.
    Again, very nice job, enjoy.
  • Marty913
    Marty913 Posts: 760
    heiney9 wrote: »
    Time will tell on the Solens although so far they have not seemed too bright (it's early though). If they become an issue, it would be relatively easy to swap a couple caps. I used them on some SDA2's which were bright anyway (SL2000) and while they didn't tame any of the brightness, they didn't add to it at all. I have been pleased with the Dayton's however keeping in mind I'm comparing them to 23 year old factory caps. In that respect, it's hard to make a big mistake. It is difficult to A/B any of this stuff.
    TT = Audio Technica
  • SDA1C
    SDA1C Posts: 2,072
    Well done. I wonder? Are the binding posts the longs or the short? I hope they are short.
    Thanks, 1C
    Too much **** to list....
  • Vette C6.r
    Vette C6.r Posts: 1,560
    I thought the extra wood on the front side is that of a 1B.
    Are they 1C's with extra wood on the front ??
    Great job either way. Love the new XO's board.
  • SDA1C
    SDA1C Posts: 2,072
    MY 1c's have the 1x4 wood at the bottom...
  • Marty913
    Marty913 Posts: 760
    SDA1C wrote: »
    Thanks, 1C
    The Vampire IC was short, the Dayton's were long. I took the mounting plate from the front side of the Dayton's and put it on the backside (inside). That took care of the thread-length gap. Either long or short will work.
    TT = Audio Technica
  • SDA1C
    SDA1C Posts: 2,072
    Awesome! I went short all around. Whew!
    Thanks! 1C
