CD Players
The Music Hall 25.3 has mods available and uses SS for the balanced outputs. Others here are far more knowledgeable than I on DAC's. I own the PS Audio and the Music Hall and enjoy them both.
I stuck $300 in my Music Hall 25.3 DAC (less than 1K total in it, bought new) and it significantly improved tube and balanced out sound quality. Burson HD op amps, Mundorf M-Caps for op amp/tube out coupling caps and a higher quality crystal oscillator. Balanced out bypasses the tube and op amp/tube coupling caps and can be ignored for the non tube folks. It is a good design and is supplied with quality caps in it. (Nichicon Fine Gold, Panasonic FC). Some modders replace the five power filter caps with same value, but higher quality and physically larger caps and upgrade the diodes.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Changing CD's is as mundane as flipping a record.
But he likes it and gets satisfaction from it, just as you do spending weeks trying to get the best flat response curve you can when designing your own speakers. To each his/her own!
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Yeah to me racks of CDs, flipping through books of them, knowing track numbers... CD covers, etc are awesome.
I dont even know song names, I know track numbers... lol
Ahhhhh CDs are great.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I never learned track names until I went with a PC server/DAC setup. http://www.jriver.com/audio.htmlVr3MxStyler2k3 wrote: »Yeah to me racks of CDs, flipping through books of them, knowing track numbers... CD covers, etc are awesome.
Ahhhhh CDs are great."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
10-4! It is both visual and sensual.:cheesygrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I have a denon and a jolida slightly modded with EI tubes. the jolida on redbook sounds just as good if not better than my denon running sacd!
Are you into sacd's at all? -
I second the Cambridge Azur 840.
Also check out Raysonic: http://cgi.audiogon.com/cgi-bin/auc.pl?dgtltran&1321589879 -
Whats up Sean! It has been a long time since I have talked to you! Are you married yet and out of the country? lol
Lots of good suggestions to look into for sure...
Keep the feedback coming guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Unless you already own a PC that is specifically built to deliver some two-channel goodness, I'd suggest to bypass the DAC idea and focus more on a traditional disc spinner. There are a number of good ones around around/under 1k. My money would go towards the NAD 565.
What's a PC got to do with anything? I know other people suggested computer-based solutions, but I didn't. I suggested an external DAC purely for CD playback so that he could swap out the DAC and CD transport individually to get different sounds, plus I reckon that an $800 DAC plus a $200 transport will sound better than a $1000 CD player. Not every time, but the potential is there...2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
needed pictures did you???
RT1 -
So effin true.
Mongo like pretty pictures. :cheesygrin:reeltrouble1 wrote: »needed pictures did you???
RT1"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Why don't you use your current cdp as a transport and spend that money on an external DAC?
Take a look at some non-oversampling / filter-less DAC (NOS). They sound a lot different than modern DAC's. For me, going with a NOS DAC is one of the best move I ever made in audio. Don't know if it's your type of sound but just want to give a heads up on NOS DAC's. Worth a try imo.
