FS: SVS PC amp
gregit
Post edited by gregit on
Gregit,
Is this still available? I'd be interested! Could you also give me an idea what features the amp has? I'm squinting at the picture but I can't make out the words...
DaveTime is the best teacher. Unfortunately it kills all its students. -
still here...it has all the usual suspects; phase control, volume control, selectable bass boost, adjustable crossover, auto-on, and both high level and low level inputs and outputs.
Greg -
It'd be perfect for a sub project I have in mind but it my better half would go into hysterics if I started another woodworking project.
Gregit, good luck. It's an awesome price and I'm tempted to buy it and hoard it until I have time but it probably be put to better use by a fellow Polk member.
regards
gregit, if this is still available i'll take it. Send me a PM.Proud SOPA Member since 2005!
YGPM...hey I'm originally from IN....where the hell is Bright?
PUT ME ON DECK IT THAT FALLS THRUDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Hoosier21...funds are coming my way. If for some reason it doesn't work out i'll give you a shout.
Thx,
Greg -
no problem, sounds like it is a done deal, thanksDodd - Battery Preamp
Thanks nebborjk!! Let me know how it works out for you.
Greg
