FS: SVS PC amp
gregit
Gregit,
Is this still available? I'd be interested! Could you also give me an idea what features the amp has? I'm squinting at the picture but I can't make out the words...
DaveTime is the best teacher. Unfortunately it kills all its students. -
still here...it has all the usual suspects; phase control, volume control, selectable bass boost, adjustable crossover, auto-on, and both high level and low level inputs and outputs.
Greg -
It'd be perfect for a sub project I have in mind but it my better half would go into hysterics if I started another woodworking project.
Gregit, good luck. It's an awesome price and I'm tempted to buy it and hoard it until I have time but it probably be put to better use by a fellow Polk member.
regards
gregit, if this is still available i'll take it. Send me a PM.Proud SOPA Member since 2005!
PUT ME ON DECK IT THAT FALLS THRUDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Hoosier21...funds are coming my way. If for some reason it doesn't work out i'll give you a shout.
Thx,
Greg -
no problem, sounds like it is a done deal, thanksDodd - Battery Preamp
