Polk Monitor 60's vs Klipsch KF-28 also what receiver?
my setup:
Polk Monitor 60's - pair for 225
Polk Monitor 40's - pair for 120
Dayton 12in sub - sub for 150
polk cs20 center channel - center for 110
Pioneer VSX-821 receiver - for 200
With black friday around the corner I have been thinking of upgrading. One of my friends said he would buy my monitor 60's for 225. (so i break even). I have a $250 gift card to best buy. I went to best buy the other day and tested out the Klipsh KF-28 for front towers. They sounded great. On black friday the KF-28 will be for $220 for one wich is 50% off normal price(450 for one). I would essentially be replacing my 60's for the KF-28's for the price of my gift card and 60's. What do you guys think of the change?
Or do you guys think I should keep my current setup and opt for a receiver. I am confused on which one to get. I wont one that i can use for a long time and will not be lacking in power. I would prefer to get it from best buy just because i have $250 gift card. I am not opposed to looking at better deals for a receiver online somewhere. I could prob spend about $500
what do you guys think?
swap speakers?
get new receiver?
do both?
please help
swap speakers?
get new receiver?
do both?
please help
Post edited by sheets on
or I guess i could move my 60's to surrounds and sell my 40's
$225 for used M60's is a great deal... for you. I'm selling a pair of M60's to a friend of mine for $120 later this week, and I'll be trying to get about $240 for the M70's I have.
I would keep the M60's for the surrounds. I've got them as surrounds now, and they are great for movies. I used to have M30's for the surrounds and they don't sound nearly as good. I know lots of folks like bookshelf speakers for surrounds, but they don't sound right to me when mixed with larger speakers.AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC. -
Personally stick with what you got now speaker wise, and upgrade your AVR to something with a little more power and your speakers will sound better.
Look at accessories4less.com @ refurbished Onkyos. They are a manufacture authorized dealer so you get a 1 year warranty on them, and they are normally at a deep discount. You should be able to get a decent model (one w/ pre-outs) for your 500. Audyssey XT32 even. Then if you ever want more power you can just add an external amp rather than re-buy a whole new AVR.
Otherwise I would say look for a SC model Pioneer with the ICE amps. That should whet your whistle quite nicely, but I havent seen one in the price range your talking about yet.
If you like Denon (I personally wouldnt w/o a dedicated amp) Dakmart.com is also an authorized reseller of their gear."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
My Onkyo came with a 2yr warranty instead of 1yr from a4l.com. I would search best buy to see if they have any clearance SC-35's sitting around. Mine came in just a hair over your budget...but I would have beat up a bum or two to get the extra funds (no, not really, but still).
I got an NR-807 for some stupid low amount (search the forum, bet you can find it!) and love it as well.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
If your wanting to up grade then I would look at the RTI or RTI A's or if you want to try klipsch then go for the RFAVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
You could try a Onky TX-NR709 from accessores 4 less for around $500 or a TX-NR809 for $629.
http://www.accessories4less.com/make-a-store/category/AVReceiver/Home-Audio/Home-Theater-Receivers/1.html?&r=4ec1c6c3AVR: Onkyo Tx-NR808
Rear: FXI A4
check out woot! today. decent Pio receiver at a great price.
http://www.woot.com/ -
Thanks for the information guys. I think i am going to look for a new receiver for now with some more kick and have pre outs. I saw the woot deal today for the VSX - 1021 I currently have the 821 and im pretty sure they both dont have preouts and the only upgrade is having network ability. I'm looking for a receiver that I can upgrade and use for the next 7 or so years.
Thanks for all the ideas
