TL2B - What is the purpose of the 5.8uf capacitor and 2.7ohm resistor?
PreCd
I have completed my upgrade to my crossovers in my SDA2Bs........thanks to ALL on this forum for helping me. I could not have completed it without your advice.
My question is concerning the 5.8uf capacitor. What is it's purpose?
How about the 2.7ohm resistor? Specifically what are they both accomplishing in the circuit?
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Marantz CD5004
Adcom GFA-545
Post edited by PreCd on
Maybe a Zobel network? to compensate the impedance!Make it simple...Make it better!
The 5.8uf/2.7ohm cap/resistor in parallel is a contour circuit. http://www.diyaudioandvideo.com/Calculator/Contour/Help.aspx"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ok thanks guys. That helps me understand what the two are doing in there. One more question. The circuit only is working in conjunction with the tweeters and not the drivers right?
KevinSDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp -
Correct."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
SDA2BTL
Marantz CD5004
Adcom GFA-545
