TT upgrade question.
BeRad
BeRad Posts: 745
edited November 2011 in 2 Channel Audio
I just bought a cheap entry-level tube stage for MM carts and am thrilled with the improvement. I am not sure when I am going to go on to the next upgrade, but I am starting to think about it already.
I am pretty sure that aside from getting some decent tubes, my next best choice is to do something on the TT.
I have a Thorens TD-316 with the stock TP21 tonearm and a shure mx97e cart. I have read that the TP21 is a fairly poor arm and was thinking about getting something like a rega rb300 arm as my next upgrade.
My question is. Do you, the experts, think that a tonearm upgrade is worthwhile or would I be better off getting an entirely new TT? I don't want to spend more than 500 total for an arm, but I can do that sooner than spending a grand on a table (which would probably be my budget down the road). Are there any other options I should be thinking about for improving the sound and experiencing the joy of buying new stuff?
Post edited by BeRad on
  • doctor r
    doctor r Posts: 837
    You might check out the AudioGon listings. There are some Rega turntables listed for less than $500 that include the RB300 arm. You would get a different table to try and if you like yours better then you can move the tonearm to it. Just a thought.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
