CNC Bubinga JBL 2397 "Smith" horns
Wardsweb
Here is a pic as some 1" African bubinga was being machined into custom horns. The holes you see are where the bolts go through to hold the CNC billet aluminum vanes.
Post edited by Wardsweb on
Here is a finished set with the custom CNC billet vanes. The wood is just as it was coming off the CNC. It has not been sanded yet. So it will only get better.
Here is how they go together. They will actually bolt together with inserts in the top half of the horn for the bolts to thread into.
Here is a look head on. Still need to sand, polish the vanes, apply Danish oil and make some stands.
These will be used along with a pair of JBL 2405 tweeters with my JBL C50 Olympus speakers.
Beautiful work! Simply stunning.--Gary--
Beautiful work. Do you have access to a CNC router, or did you hire the cutting out?Wristwatch--->Crisco
There is a plastics supplier/fabricator about 3 or 4 miles from my house. They will CNC anything. Their CAD designer is an audio guy. His is coming over for a listen.Beautiful work. Do you have access to a CNC router, or did you hire the cutting out? -
So what does it cost to CNC something like that? If you don't mind me asking.....--Gary--
This was two hours of machine time. Different shops have different labor rates but you can figure $60-80 an hour as a ball park.So what does it cost to CNC something like that? If you don't mind me asking..... -
Ok sanding was a lot more of a task than I had anticipated. The very hardness that made machining nice, makes sanding difficult. I ended up using 120 grit on a random orbital palm sander to get the paper to even cut. I then hand blocked a little with some 320. Running your hand over it, you would think it had been finished in 600 grit.
Here is a picture as the first coat of Danish oil was going on.
Beautiful work and wood.
We don't hear from you often, but when we do it always seems to be an awesome project, like your garage find and refurbed Mac/amps2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
If you ever make it over to San Antonio, we'll spend a day playing in the audio sandbox.txcoastal1 wrote: »We don't hear from you often, but when we do it always seems to be an awesome project, like your garage find and refurbed Mac/amps -
A couple pics in daylight
Will do
I graduated from Churchill a couple moons ago in SA, family is still there. Really appreciate the wood work, beautiful...my after school and weekend job in SA was cabinet building
Cheers
Ron2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Comparing the JBL 2397clone against an Altec 511B, the JBL wins hands down. The mid range is smoother and warmer. The 511B seems bright and edgy that I can only attribute to the undampened aluminum horn.
The adapter is a one off prototype I threw together. It is made from two pieces of 3/4" batic birch. The first has a 1" hole and recessed bolt holes to mount the LE85. The second piece transitions from the 1" hole to a rectangle that matched the horn. The two pieces bolt directly to the horn. The wood is so dense, I drilled and tapped it for 1/4x20.
Those are beautiful! I'd probably just sit there and stare at them. No even listening to music.--Gary--
awesome work... Have any of that wood left?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Looks great Luther. You always do some amazing work and I'm sure it sounds as good as it looks.Make it Funky!
I have a couple planks about five feet long but only half as wide. When I want more I just make a run up to McKinney Texas to http://www.mckinneyhardwoods.comnooshinjohn wrote: »awesome work... Have any of that wood left? -
They look very nice and the finish is better than I expected.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I bet that they sound as gorgeous as they look! Outstanding series of progress posts! I am so happy that the Bubinga worked out so well for you Luther!
If you need any extra we have plenty of equal quality available! Thanks again for the business and may your horns and the construction be an inspiration to others!
Best regards,
Michael Mastin
McKinney Hardwood Lumber
McKinney, Texas -
Welcome Mike! Glad to made it here. There are a lot of great guys and gals here. You may know Russman. He lives just a few miles from you .McKinneyMike wrote: »I bet that they sound as gorgeous as they look! Outstanding series of progress posts! I am so happy that the Bubinga worked out so well for you Luther!
Best regards,
Michael Mastin
McKinney, Texas
I'm sure I will be by your place when my next project comes around. -
That African Bubinga wood looks fantastic! I was thinking of redoing my 3.1TL's and more recently my 2.3TL's with this wood. I love the look of it. Fantastic job on the horns Luther!
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I have put up a build page with more pictures on these JBL 2397 clones.
http://wardsweb.org/audio/Smith%20Horn/ -
That's amazing.
Are the top and bottom wood pieces just flat pieces?
How do I get the plans for the curves?
