CNC Bubinga JBL 2397 "Smith" horns
Wardsweb
Wardsweb Posts: 944
edited December 2011 in DIY, Mods & Tweaks
Here is a pic as some 1" African bubinga was being machined into custom horns. The holes you see are where the bolts go through to hold the CNC billet aluminum vanes.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Here is a finished set with the custom CNC billet vanes. The wood is just as it was coming off the CNC. It has not been sanded yet. So it will only get better.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Here is how they go together. They will actually bolt together with inserts in the top half of the horn for the bolts to thread into.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Here is a look head on. Still need to sand, polish the vanes, apply Danish oil and make some stands.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    These will be used along with a pair of JBL 2405 tweeters with my JBL C50 Olympus speakers.
  • halo71
    halo71 Posts: 4,644
    edited October 2011
    Beautiful work! Simply stunning.
    --Gary--
  • strider
    strider Posts: 2,568
    edited October 2011
    Beautiful work. Do you have access to a CNC router, or did you hire the cutting out?
    Wristwatch--->Crisco
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    strider wrote: »
    There is a plastics supplier/fabricator about 3 or 4 miles from my house. They will CNC anything. Their CAD designer is an audio guy. His is coming over for a listen.
  • halo71
    halo71 Posts: 4,644
    edited October 2011
    So what does it cost to CNC something like that? If you don't mind me asking.....
    --Gary--
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    halo71 wrote: »
    This was two hours of machine time. Different shops have different labor rates but you can figure $60-80 an hour as a ball park.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Ok sanding was a lot more of a task than I had anticipated. The very hardness that made machining nice, makes sanding difficult. I ended up using 120 grit on a random orbital palm sander to get the paper to even cut. I then hand blocked a little with some 320. Running your hand over it, you would think it had been finished in 600 grit.
    Here is a picture as the first coat of Danish oil was going on.
  • newrival
    newrival Posts: 2,016
    edited October 2011
    beautiful work!
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited October 2011
    Beautiful work and wood.
    txcoastal1 Posts: 13,520
    edited October 2011
    We don't hear from you often, but when we do it always seems to be an awesome project, like your garage find and refurbed Mac/amps
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    txcoastal1 wrote: »
    If you ever make it over to San Antonio, we'll spend a day playing in the audio sandbox.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    A couple pics in daylight
    edited October 2011
    Wardsweb wrote: »
    Will do
    I graduated from Churchill a couple moons ago in SA, family is still there. Really appreciate the wood work, beautiful...my after school and weekend job in SA was cabinet building
    Cheers
    Ron
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Comparing the JBL 2397clone against an Altec 511B, the JBL wins hands down. The mid range is smoother and warmer. The 511B seems bright and edgy that I can only attribute to the undampened aluminum horn.
    The adapter is a one off prototype I threw together. It is made from two pieces of 3/4" batic birch. The first has a 1" hole and recessed bolt holes to mount the LE85. The second piece transitions from the 1" hole to a rectangle that matched the horn. The two pieces bolt directly to the horn. The wood is so dense, I drilled and tapped it for 1/4x20.
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Here is a final pic of the setup.
  • halo71
    halo71 Posts: 4,644
    edited October 2011
    Those are beautiful! I'd probably just sit there and stare at them. No even listening to music.
    --Gary--
    nooshinjohn Posts: 26,181
    edited October 2011
    awesome work... Have any of that wood left?
  • gidrah
    gidrah Posts: 3,050
    edited October 2011
    Looks great Luther. You always do some amazing work and I'm sure it sounds as good as it looks.
    Make it Funky! :)
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    I have a couple planks about five feet long but only half as wide. When I want more I just make a run up to McKinney Texas to http://www.mckinneyhardwoods.com
  • dorokusai
    dorokusai Posts: 25,661
    edited October 2011
    They look very nice and the finish is better than I expected.
  • McKinneyMike
    McKinneyMike Posts: 1
    edited October 2011
    I bet that they sound as gorgeous as they look! Outstanding series of progress posts! I am so happy that the Bubinga worked out so well for you Luther!
    If you need any extra we have plenty of equal quality available! Thanks again for the business and may your horns and the construction be an inspiration to others!
    Best regards,
    Michael Mastin
    McKinney Hardwood Lumber
    McKinney, Texas
  • Wardsweb
    Wardsweb Posts: 944
    edited October 2011
    Best regards,
    Michael Mastin
    McKinney, Texas
    Welcome Mike! Glad to made it here. There are a lot of great guys and gals here. You may know Russman. He lives just a few miles from you .
    I'm sure I will be by your place when my next project comes around.
  • headrott
    headrott Posts: 5,496
    edited October 2011
    That African Bubinga wood looks fantastic! I was thinking of redoing my 3.1TL's and more recently my 2.3TL's with this wood. I love the look of it. Fantastic job on the horns Luther!
    Greg
  • schwarcw
    schwarcw Posts: 7,360
    edited October 2011
    Beautiful job Luther!
    Carl
  • Wardsweb
    Wardsweb Posts: 944
    edited November 2011
    I have put up a build page with more pictures on these JBL 2397 clones.
    http://wardsweb.org/audio/Smith%20Horn/
  • saemark30
    saemark30 Posts: 146
    That's amazing.
    Are the top and bottom wood pieces just flat pieces?
    How do I get the plans for the curves?
