PSW1200 amp
rayzor_jon
rayzor_jon Posts: 9
edited March 2004 in Troubleshooting
Just got a new amp from Polk for my PSW1200. I've hooked it up and it doesn't seem to be hooked up right (not on the outside, but on the inside- amp to drivers) I see a green "jumper cable", that should go between the two negative connections on the drivers right? Any suggestions or ideas of where to look for info?
Post edited by rayzor_jon on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited March 2004
    Hello,
    The two drivers are connected in series, meaning the green wire provides a connection from the negative terminal, of one driver, to the positive terminals of the second driver. So, there should be a red wire which connects to the positive terminal of one of the drivers. Then the green wire would connect to the negative terminal of that same driver to the positive terminal of the second driver. Then the remaining black wire connects to the negative terminal of this second driver.
    The same as batteries in a flashlight, the positive of one battery goes against the negative of the first battery.
    Regards, Ken
