No wonder my amp weighs 100 pounds
thsmith
While Susan was at the movies with the grandkids I thought I would Dynamat the transformer cover and cabinet of my Wright amp.
I had never had the nickel plated cover off and WOW those trannys are huge. Now when I thump the cabinet or tranny cover it goes thud instead of ringing. Warming up the fire bottles to see if I can hear a difference.
Post edited by thsmith on
Probably the first time I have ever heard that lol..
P.S. that amp looks great...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Probably the first time I have ever heard that lol..
I agree! Very nice, they look like the ones on my old Pilot Sa-232, were they vintage sourced?Speaking of huge trannies :eek:
Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
Supposedly George Wright used magnaquest transformers but when contacted mq he said George also sourced local nw pacific people to. Amp was made in 2003.Speakers: SDA-1C (most all the goodies)
Be careful in placement of Dynamat in areas that get hot from the tube rectifiers and the like. Dynamat will melt and turn to a semi-liquid goop and become very uncool.
For anyone else thinking of doing this, make sure you run your amp for a good day and maybe do a solid couple hours of heavy listening to determine and ensure where your hot spots are prior to application of anything like this. This is not an easy thing to remove after the fact.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Agree Doro, thanks for pointing that out. I checked my gear before hand. Here are the specs if anyone else plans to do this.
Description:
Dynamat Xtreme is a patented, lightweight elastomeric butyl and aluminum constrained-layer vibrational damper. Dynamat Xtreme conforms and fuses easily to sheet metal and other hard substrates. Material performance is optimized for temperature ranges between 14?F and 140?F (- 10?C to +60?C). Material can withstand temperature extremes between -65?F and +300?F (-54?C to +149?C) and is highly resistant to aging.
*Speakers: SDA-1C (most all the goodies)
Nice Amp!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Thanks Dan, I like it.Speakers: SDA-1C (most all the goodies)
It's not just that. Those covers are metal for a good reason - the transformers need to dissipate heat. Your dynamat is a great thermal insulator, so those transformers' life is going to be much shorter insulated like that.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Never thought about that way, I think I will just take the cover off and let the trannys breath.
Any issue doing that? Or is the cover there for more than looks?Speakers: SDA-1C (most all the goodies)
Yup - heavy amps. I have a Proceed AMP5 for my HT and when I am ready to retire and move, I will probably not be able to lift it. It weights 120 lbs. Then again, I will not be moving anything except my 2CH and some of HT gear.Michael
NORTH of 60° -
Cover is most likely there to meet UL safety requirements or could be just for looks. If you believe that the cover is vibrating/buzzing because the transformers are slightly vibrating, I'd just take it off or maybe mount it back with some better way.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
It's off and the dynamat peeled right off the cover.Speakers: SDA-1C (most all the goodies)
