No wonder my amp weighs 100 pounds
thsmith
thsmith Posts: 6,082
edited October 2011 in Electronics
While Susan was at the movies with the grandkids I thought I would Dynamat the transformer cover and cabinet of my Wright amp.
I had never had the nickel plated cover off and WOW those trannys are huge. Now when I thump the cabinet or tranny cover it goes thud instead of ringing. Warming up the fire bottles to see if I can hear a difference.
Post edited by thsmith on
    EndersShadow Posts: 17,687
    edited October 2011
    thsmith wrote: »
    Probably the first time I have ever heard that lol..
    P.S. that amp looks great....
  • stuwee
    stuwee Posts: 1,508
    edited October 2011
    I agree! Very nice, they look like the ones on my old Pilot Sa-232, were they vintage sourced?
    Speaking of huge trannies :eek:
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • thsmith
    edited October 2011
    Supposedly George Wright used magnaquest transformers but when contacted mq he said George also sourced local nw pacific people to. Amp was made in 2003.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2011
    Be careful in placement of Dynamat in areas that get hot from the tube rectifiers and the like. Dynamat will melt and turn to a semi-liquid goop and become very uncool.
    For anyone else thinking of doing this, make sure you run your amp for a good day and maybe do a solid couple hours of heavy listening to determine and ensure where your hot spots are prior to application of anything like this. This is not an easy thing to remove after the fact.
  • thsmith
    edited October 2011
    Agree Doro, thanks for pointing that out. I checked my gear before hand. Here are the specs if anyone else plans to do this.
    Description:
    Dynamat Xtreme is a patented, lightweight elastomeric butyl and aluminum constrained-layer vibrational damper. Dynamat Xtreme conforms and fuses easily to sheet metal and other hard substrates. Material performance is optimized for temperature ranges between 14?F and 140?F (- 10?C to +60?C). Material can withstand temperature extremes between -65?F and +300?F (-54?C to +149?C) and is highly resistant to aging.
  • danz1906
    danz1906 Posts: 5,144
    edited October 2011
    Nice Amp!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • thsmith
    edited October 2011
    Thanks Dan, I like it.
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2011
    dorokusai wrote: »
    It's not just that. Those covers are metal for a good reason - the transformers need to dissipate heat. Your dynamat is a great thermal insulator, so those transformers' life is going to be much shorter insulated like that.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • thsmith
    edited October 2011
    Never thought about that way, I think I will just take the cover off and let the trannys breath.
    Any issue doing that? Or is the cover there for more than looks?
  • janmike
    janmike Posts: 6,146
    edited October 2011
    Yup - heavy amps. I have a Proceed AMP5 for my HT and when I am ready to retire and move, I will probably not be able to lift it. It weights 120 lbs. Then again, I will not be moving anything except my 2CH and some of HT gear.
    Michael ;)
    NORTH of 60°
  • ViperZ
    ViperZ Posts: 2,046
    edited October 2011
    thsmith wrote: »
    Cover is most likely there to meet UL safety requirements or could be just for looks. If you believe that the cover is vibrating/buzzing because the transformers are slightly vibrating, I'd just take it off or maybe mount it back with some better way.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • thsmith
    edited October 2011
    It's off and the dynamat peeled right off the cover.
