dac player for usb 32gb drive to play flac files
edited November 2011 in 2 Channel Audio
hello i am looking for a dac player the will allow me to use my 32gb usb drive,i have lots of flac files. any suggestions 200-400 range.
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
Welcome!
    edited October 2011
    The only drive player I know of is the Bryston BDP. It's supposed to be awesome, but it runs 2300 new, 1700ish used.:eek:
    Can you used a laptop or other computer? If so, your options will be greatly increased. There are a bunch of quality USB DACs and USB > SPDIF converters in that price range, but the ones I'm familiar with aren't "players", so you have to use a computer.
    Sorry I'm not much help! :redface:
    edited October 2011
    What is a DAC player? Do you mean a cd player that has a digital input? If so, you can't just hook an HD to the digital input. I am not at all understanding your terminology, nor have you explained what you are trying to do or the gear you already have to use with it.
    Perhaps you mean something like the Squeezebox Touch? While it has a USB input, it's not designed to actually take large blocks of data and "manage" it for organized playback. The USB input was designed as a way of having friends plug in a smaller thumb drive to play a few files, not manage an entire library of files from a large HD. It doesn't have the processing capabilities.
    There are units out there like the Logitech Transporter (the bigger brother to the Squeezebox) but they are costly. I'm not sure an inexpensive alternative that sounds good is available. I believe the X-Box and/or Playstation do this to some degree, but I'm sure the sound is compromised. But then again I have no idea what your expectations are for quality sound.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul!
    edited October 2011
    ok i have a onkyo nr708 that accepts usb flash drive with files and plays it thru with no problem,it supports 24/96,i recently just sold mine, and have upgraded to a pioneer elite sc37 , but it does not play flac thru usb only network, i would rather get a usb dac player that can do the same as the onkyo nr708 receiver.see pic onnr708 on left usb flash drive plugged in DSC02420.jpg look at screen.
    edited October 2011
    something like this but in the 200 to 400 range http://www.avguide.com/review/naim-dac-digital-converter-hifi-plus-71
    edited October 2011
    edited October 2011
    You could also look for a used network audio device like the Denon DNP-720AE or Marantz na7004. Both appear to do what you want but may be hard to find for $400.
    edited October 2011
    actually they both are on ebay, but 500 each, any other suggestions
    edited October 2011
    I just noticed in your sig you are using two different type caps in your LSi 15's. Why?
    edited October 2011
    claritycap wins sounds clearer than sonicaps
    edited October 2011
    So...........are you going to make them the same someday so your sound isn't lop-sided?
    edited October 2011
    [PHP][/PHP]
    heiney9 wrote: »
    yes of course,back to topic , any other usb flash players dac out there for 300-400
    edited October 2011
    deseroner wrote: »
    [PHP][/PHP]
    Sorry to pick you apart, but there is a big difference between a full blown hard drive vs. a flash drive. I guess I originally assumed you were talking about a HD not a flash/thumb drive. Why not look into the Squeezebox Touch? It can accomodate a USB flash drive if the root directory is set-up properly. It will be cumbersome and probably a little slower than if you were using it as a wireless music server, but with the screen you will be able to navigate and it has a remote.
    I don't think you will find much else in your price range.
    Good luck
    edited October 2011
    heiney9 wrote: »
    Good luck
    from what i see i agree that is the cheapest method,hopefully the sound is good.
    edited October 2011
    deseroner wrote: »
    It's pretty darn good, although using a dedicated linear power supply improves things over the wall wart that comes with it. By that time though the cost of the unit and external PS takes it out of your budget. For what it is as a stock unit, it's pretty good.
    edited October 2011
    heiney9 wrote: »
    well i plan on running it thru my pioneer sc-37.
    edited October 2011
    deseroner wrote: »
    Doesn't change anything about what I said. I run mine through a separate stand alone dac and the linear power supply made a big difference. The dac's in the SQB Touch are pretty good and might give the sc-37 dac's a run for their money. Either way you will get some decent playback. I haven't really used the USB input so be sure and do your research to make sure it will work in the manner you expect it to via the USB input.
    edited October 2011
    I am in pretty much the same situation as the OP, I want to use my external hard drive with all of my music.
    Right now I am using a laptop to play via usb DAC but there is some jitter because it is not Asynchrounous usb.
    So there are three options to think about:
    1. Asynchronous usb to spdif/coax converter then use other input in DAC
    2. Buy a DAC with Asynchronous usb
    3. Squeezebox Touch using spdif/coax output to DAC
    I am trying to decide which option is best. It will weigh heavily on if I want to use a laptop or squeezebox to manage music.
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
    edited October 2011
    You guys are making this pretty complicated. The main idea with the SQB is to run it wirelessly from a computer which can be in another part of the house where you would have a HD with your music on it. My computer (a networked 2nd computer) is downstairs and I stream everything wirelessly to the SQB which is sitting on top of my dac in the main rig. My main computer is networked to the slave computer in the basement so I can rip my music in my office and send it to the computer in the basement.
    Or you can just use your main computer and stream wirelessly from there.
    edited October 2011
    I would set up the Squeezebox server on an office computer and stream it on the network.
    edited October 2011
    cdn5003 wrote: »
    This one.
    This is, of course, personal preference, but I will always vote this way.
    Using a full blown computer to manage music is invaluable to me. So easy, you can do anything. Another plus side is that with a good USB > SPDIF converter you can use any external DAC you want, including any older, awesome models that don't do USB, so your options on the used market are limitless.
    I'd recommend the Musical Fidelity V-Link as a very good, less expensive option at about 120.
    The best I've used is the Audio GD Digtial Interface with Audio GD external power supply. Not only does it look awesome, it really sounds great. Sounds better than my Parasound CDP-1000 CD transport. That's not a boutique transport by any means, but I was pretty stoked to be able to get playback from my PC that could best a decent CD transport.
    The DI, with external power supply and upgraded clock, will run about 290 shipped to your door from Audio GD:
    http://www.audio-gd.com/Pro/dac/USBface/Digital1EN.htm
    edited October 2011
    This one.
    The best I've used is the Audio GD Digtial Interface with Audio GD external power supple. Not only does it look awesome, it really sounds great. Sounds better than my Parasound CDP-1000 CD transport. That's not a boutique transport by any means, but I was pretty stoked to be able to get playback from my PC that could best a decent CD transport.
    Except if he goes the route of the Squeezebox there is no USB involved. I guess the OP has to decide the exact method he wants to do and then solicite recommendations. The USB route is fine if you want a physical computer tied to the rig. It works fine for me in the office rig since the computer and associated gear is close by. But I would never want a computer running right next to my main rig, others may not care. It's one of the reasons I use the SQB and also because the SQB is a helluva lot more convenient than using a computer when sitting on the couch trying to listen to tunes.
    edited October 2011
    heiney9 wrote: »
    ......But I would never want a computer running right next to my main rig,...
    How come? Just curious.
    I think this is subjective. Having a remote may be physically more convenient, but, for me, being able to use a full blown PC interface, media player, and folder system makes managing music much more convenient than what a SQB offers. I'm still intrigued by the SQB, though, and I may give one a whirl at some point.
    I've only been into the "PC as hifi player" for a about a year, and while I feel I have arrived at a very competent solution, I always keep my ears open to better alternatives/tweaks.
    edited October 2011
    No space for one, the bulk for two and having to dick around with what you call more convenient with the "full blown PC experience". I also don't want to rip my music in my living room.
    So I gather you've never used a SQB? Because it has all the things you mention about the "full blown" PC as far as the play back, menu and folder system. In many aspect it's more convenient and you get even more choices and never have to get off the couch. I also am not fully sold on Asynchronous USB being the be all end all at this point. Atleast I don't think it's always superior. Like I said it works great in my computer rig for my office system because I'm right there to run the music the way I want, but for the main rig who the hell wants the extra bulk, noise, cables, etc running.
    I guess it comes down to personal choice, but if you have never even used a SQB - Touch I don't know how you can say a PC is better.
    edited October 2011
    heiney9 wrote: »
    I'm not saying it's better. It's definitely a different lifestyle choice, and it may present a better option for some people... like me.
    Here's what I like about running a PC as opposed to a SQB:
    - You can click through files with a mouse. This means you can create playlists in a matter of seconds. You can do anything you want... quickly.
    - The entire internet is at your disposal, not just certain apps or widgets. If it exists on the internet, it can come through your speakers. Again, it's easier to navigate the internet on a computer, with a mouse and a keyboard, than on a handheld device.
    - My PC can play any format of audio files: WAV, FLAC, SHN, APE, OgVorbis, AIFF, ALAC, WMA, MP3, etc. You name it, I can play it.
    - See above, but with all video formats.
    - I do not rely on an internet connection to be able to use my system and have immediate access to all of my music.
    edit: I would like to add that you can buy a really decent PC for the price of a SQB.
    edit 2: I would also like to add that when I redo my HT, I will have a HTPC as the heart of the system. There are video cards now that output full HD 1080p 3D and the new audio formats like dolby truehd and dts ma via HDMI. This would be a good solution for the OP since his system includes a HDTV.
    edited October 2011
    You can do all that and more with the SQB with the exception of video, apps and widgets aren't used by the SQB. I would also challenge the mouse vs. remote or handheld.
    That's cool that this is your preference, nothing wrong with that. I just wanted to comment that what you think are PC strengths the SQB also does and IMO and in my use the SQB is easier to integrate.
    It seems like you are talking about a Home Theater PC since you want to surf the internet and play video. That's not really a fair comparison to the SQB which is just for music. It's not going to be an HTPC which it seems you have and want the added features. For music playback the SQB will do just about everything a PC will only it's less complicated and more user friendly, IMO.
    Anyway, the OP has to decide what direction he want's to go and what he's going to ultimately use it for.
    Again you having never used a SQB means you really can't comment on how it integrates or what it can do compared to your HTPC.
    P.s. With the SQB you don't rely on an internet connection to have access to all your music either, not sure why you listed that as an advantage to a PC vs. SQB.
    edited October 2011
    I wasn't talking about the HTPC side of things at first. I got there through rambling... i'm a little hungover....
    I am going to try a SQB at some point, mainly just to evaluate the SQ differences between it and a good async USB > SPDIF converter. Whichever one wins in SQ will be my end point, regardless of the interface differences.
    edited October 2011
    But with the computer you also have to buy a DAC. The SQB has internal DAC's that sound pretty darn good by themselves. So in the end unless you are using a receiver with built in DACs and a USB connection it will cost about the same or more.
    edited October 2011
    Just be sure to compare apples to apples......meaning using the same DAC for each device.
    edited October 2011
    You really need to use a SQB Touch because your perceptions are way off about what it can and can't do and the convenince, etc.
    edited October 2011
    heiney9 wrote: »
    duh.
    fine.
Welcome!
Welcome!
