Memory question for Athlon XP PC rebuild.
fbm211
fbm211 Posts: 1,488
edited October 2011 in DIY, Mods & Tweaks
I have 2x 256mb pc2700 DDR (and 2x 128mb chips)
Do I need to add a 512 DDR in the middle for this to work properly.?
Or is that only for dual channel memory support only.(And did these systems even support dual channel memory at that time.)
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2011
    Can you find your motherboards manual? It's been awhile for me, but my last build was an AMD athlon setup on an ASUS MB. You'll have to see what the MB and associated BIOS will support.
    IIRC, my Asus only supported DIMM memory--but I could be wrong on that point.
  • fbm211
    fbm211 Posts: 1,488
    edited October 2011
    No mobo yet.Ive been offered some from a few polkies and am waiting to here back from nadams about a GA-7VAX he offered.Most of the boards support up 3 gigs but I know winXP home only supports 2.5 or something like that.I figure 1 gig should be enough for that era PC
