Bi-Wire pin/blade plate
bluecomet
bluecomet Posts: 1,118
edited November 2011 in Wanted (WTB) Classifieds
I am looking for the plate on the back of an SRS speaker that can be bi-wired. It needs to be pin/blade. Let me know if you have one. Thanks.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
    Toolfan66 Posts: 18,149
    edited October 2011
    Why do you need the whole plate?? If it's just the pin/blade socket you need you can just swap that out..
    I might have one if not I'm sure someone else does!! I will look and see what I have..
  • bluecomet
    edited October 2011
    I can't get the socket out of the plate. Do you know how to remove it. It looks like it is revited in the plate. I have another socket, if I can get it out.
    edited October 2011
    Take a drill bit to the top of the head (start with an 1/8") drill lightly on the top of the rivit head, you will cut through the head and will pop off.
    Take the hot glue off the back side and wiggle it till it comes free, then of course take your soldering iron and de-solder the wires.
    Solder the replacement and install with new rivits or some small screws with nuts and hot glue it back up..
    Important!!! You should not have to drill all the way through!!! Only enough to crack the head of the rivit..
    Larry.
    If you would like me to fix it send me the parts and I will do so free of charge just pay the shipping..
  • bluecomet
    edited October 2011
    I think I will take you up on your offer. You have a PM.
    edited October 2011
    Fixed and ready to come back home to you!!! I will have it in the mail by Monday..
    txcoastal1 Posts: 13,518
    edited October 2011
    TFLF-Your one of the reasons CP-rules
  • stubby
    stubby Posts: 723
    edited October 2011
    Well, Larry that was a very nice gesture on your part! Part of what makes this place what it is.
    bluecomet - I have to know - what is the Number 1 Rated Water Park in PA? (from your photo)
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
    edited October 2011
    stubby wrote: »
    It was perfect timing as I have been home taking care of the wife as she had Lasik PRK eye surgery and when I went to the mail box I was happy to have something to work on..
    :cheesygrin:
  • bluecomet
    edited October 2011
    Your the best Larry. Thanks for the assist. I owe you one. Jim
    stubby the Number 1 Water Park in PA according to the pamphlet you saw is Camelbeach Mountain Waterpark. My kids really enjoy it.
  • Systems
    Systems Posts: 14,872
    edited October 2011
    Why not install a 5 way binding post since you went that far?
    Testing
    Testing
    Testing
    Mr Blue did you receive this back??
