SVS AS-EQ1 discontinued by SVS
bsoko2
bsoko2 Posts: 1,449
edited October 2011 in Electronics
SVS AS-EQ1 has been discontinued by SVS. I was checking the website for SVS and did not see it there so I called customer service. I was told that they no longer sell the units due to Audyssey XT32 being so popular. So, hang on to the ones you have as the price will go up due to not having the ability to buy new.
email from Ed Mullen:
Hi Bill:
The AS-EQ1 has been discontinued. Audyssey MultEQ XT32 (now found in many top-end AVRs) essentially has the same performance (duals subs and 512x resolution). You may be able to find a used AS-EQ1 on Audiogon or AVS classified. Thanks for the inquiry, and if you have any other questions, please don't hesitate to ask.
Ed Mullen, PE
Director - Technology and Customer Relations
Specialty Technologies
SVSound
Office: (585) 542-5037
Toll-Free: (877) 626-5623
Mobile: (585) 451-4140
Fax: (719) 466-2022
Email: emullen@svsound.com
Skype: svs_ed
Post edited by bsoko2 on
  • DMara
    DMara Posts: 1,434
    edited October 2011
    bsoko2 wrote: »
    With that logic, you should have kept your AS-EQ1 instead of listing it on the Gon now :biggrin:
    http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1324165376&/Svs-as_eq1-Audyssey-subwoofer-
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • bsoko2
    bsoko2 Posts: 1,449
    edited October 2011
    DMara wrote: »
    Price is now 675!
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    Average AVR price + the purchase price of the AS-EQ1 = better avr with built in Audyssey Mulit Eq XT32.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • bsoko2
    bsoko2 Posts: 1,449
    edited October 2011
    To get the XT32 which the SVS AS-EQ1 has, you have to layout alot more $$$$ then the cost of the EQ1. Then there are those with non Audyssey AVR's.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2011
    I don't think the value will all of a sudden jump up because they're no longer selling them. There's other alternatives out there.
  • jbooker82
    edited October 2011
    Onkyo TX-NR809 is a pretty mid level avr. MSRP is $1,100. It comes with Audyssey XT. Add $800 bucks to that and your getting close to the MSRP of the Onkyo TX-NR3009 for $2,200 wich comes with Audyssey XT32. And you get all the other benifits of running a higher end AVR and not just a mid grade avr with XT32 equivilant. You get a lot more for your money when buying a built in AVR Audyssey XT32 than buying an add on and running mid level avr.
    Then add in the fact that you can get a refurb 2010 Onkyo TX-NR3008 for $1,000 or Onkyo's top of the line TX-NR5008 for $1,500. It makes it hard to justify $800 for an add on when you can get it built in + all the added features of a high end AVR for less cash than the mid level avr + AS-EQ1.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited October 2011
    More and more people who bought the AS-EQ1 are buying the new AVRs with the Audyssey XT32 feature and selling their used AS-EQ1 to recoup the money spent on the new AVR. Not a bad idea...
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    Now don't bark at me because I haven't done much research. But isn't the AS-EQ1 a glorious sub eq? It's essentially a different device like the SMS-1 from Velodyne but EQ's subs a little differently? (Assuming how this Audyssey does it?)
    EndersShadow Posts: 17,687
    edited October 2011
    Drenis wrote: »
    No worries Drenis. Here is the skinny:
    The SMS-1 allows you to EQ mutliple subs AS ONE UNIT. So you can connect 3 different subs up, but it treats them as one unit and applies the same filters/settings to all of them. The SVS model lets you EQ the subs INDEPENDENT of each other. So one sub can have a higher gain than another, have different distances, etc. So if you want to EQ your subs independing w/ the SMS-1 you need one unit per sub you want to EQ. That makes a world of difference in some rooms.
