crossover help
grb3963
I have a cs1 up front. the correct crossover is 100.
If i set it to 80 where it sounds better will that setting damage the speaker??
thanks 4 any help
thanks 4 any help
Post edited by grb3963 on
No it will not harm the speaker. Set it to where it sounds the best for you.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
