Video switching...
Grimster74
This is a curosity question. After alot of reading it seems to be a 50/50 split. Do you do all your video switching at your television or do you allow your receiver to have total control of your video switching. Me personally, I allow my receiver to do the switching for me. Alot of other people I've spoke with said they seem to get better picture quality running there video inputs to the television and they're audio to the receiver but seems to me price of cables will go through the roof do to having to run multiple cables to your television. I mean why else would you buy a receiver with all your inputs they come with especially with alot of the newer receivers having video up conversion. Has anyone tried running just your audio to the receiver and the video to the television and come out with better results. Once my Denon 3805 comes in I may try this just to see the results, hell, I'll have everything torn apart anyways.:D
Post edited by Grimster74 on
With a FP I'm limited to 1 configuration, but it works great. I think that in some cases a receiver/preamp could introduce some video noise but most people wouldn't notice anything. Generaly speaking, keeping the video and power cables seperated can make a difference, especially if the video cables are the poor quality cables supplied with the electronic gear.
I run directly to the TV because why introduce 1 more step into the process. This is much like the advice I received from Russ regarding digital coax verse TOSLinks... why add another coversion process?
HBomb***WAREMTAE*** -
after all, that's why my receiver has 5 or more video inputs.. i choose to go through my receiver, My tv is a few years old and has 2 inputs only.. I don't have a system in which im so critical that i can tell the difference ... That's just me though
Makes it easier with the denon, i turn on a video source and it will play any of them through one S-video cable.. No changing inputs on the TV, video1, video2, 3 , 4, so on, I switch on dvd, its there.. i switch on vcr or cable/dvr box its there..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I run Three Component gear pieces, my TV has hookup for only two of the three so I do both!!
I could not vote because no option for both:( . -
Well how do you get the moderator to add "both". Sorry about that, never even crossed my mind that some people use both.:)Money Talks, Mine says Goodbye Rob!!!!
Given the distance to my TV, using the AVR makes the most sense.More later,
Tour...
Vox Copuli
Yeah, I upgraged my receiver to be able to handle the video (HDTV) through it with a Denon 2803 ( 100mhz). The TV is a 55" Mitsuibishi , and frankly I was disappointed with the video through the receiver. Now keep in mind that the video through TV is phenommenal, crisp, sharp detail, and through the reveiver it was noticably softer. I spent big money for a super picture, so..... I'm back splitting the video and audio coming out of the cable box. Even this way, I'm very pleased with the Denon and its abilities. Pictures on system showcase.
I only have a DVD player, so switching thru my AVR would be silly. I use HDTV on Component input, from the cable box...and the DVD on S-Video. The AVR does not perform upconversion at that level, so direct to TV again is the better idea for me.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
In regards to cable costs, don't you actually need more cables to run through your AVR. Components from the AVR to the monitor, and also from all the respective sources to the AVR. More $ on cables vs. direct to monitor is why I do not use my AVR.AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One -
I use both as well. My AVR does not have DVI switching so it goes directly to the TV. Everything else is switched by the AVR.Proud SOPA Member since 2005!
I use both as well. Everything I have needs component inputs (DVD, HDTV, XBox, GameCube) and my TV only has 2 inputs, so I send some through the receiver and some to the TV. But now I have more things to plug in than I have inputs, so I may need to get an external conponent video switch.
The Denon has a 100mhz bandwith sending the video signal, so there is not much loss going through the reciever. With anything less than HDTV (1080i, 720p), there shouldn't be any loss with a video signal, so going through the amp is probably the nicest way to go (I have a big annoying delay in switching the video through the TV, so I would perfer using the amp).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
I tried using the component in/out of my Denon 5803A and went back to using the TV. I had my TV calibrated on each input for DVD, HD, etc... With each device requiring a different brightness, contrast, color... setting, I found I couldn't run all of them through one input on the TV. My HD was too dark, my SD satellite was too bright and my DVD looked perfect since the receiver's output was on the calibrated input on the TV that was set for the DVD.
Other than that, the signal was fine and I didn't notice any loss, noise, etc. Sure was nice having it hooked up, though. It upconverted my s-video to component with no loss in quality, etc.Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way -
I go through my avr but since my tv isn't crazy good like most of you peoples' I probably won't be able to tell the difference.... but hey I'll have to try going straight to my tv today and maybe I will get a better picture...
just my own experience but i tried both ways and had a much better picture hooking up video directly to the tv and audio directly to the amp, kind of a pain having to switch inputs on both units , but was worth it in my case.
