Single Binding Posts
audiocr381ve
audiocr381ve Posts: 2,588
edited October 2011 in Vintage Speakers
Okay, I've searched and searched. I'm looking for single binding posts, Cardas, to replace my SDA interconnect post so I can start using better cable. I want to leave the original speaker binding posts intact for now. I've looked over at Soniccraft and diycable.com and can't find single binding posts. Am I missing something here?
Thanks guys :smile:
Post edited by audiocr381ve on
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    Dude, I love you man. You unscrew the binding post from the little black bar it's connected too and there you have it single binding posts.
  • brgman
    brgman Posts: 2,859
    edited October 2011
    Thread jack! Audiocr381ve do you want the 4 gaskets you requested or what?
    You are one of the no response folks holding up the works here.
    I’M OFFENDED!!!!
  • drumminman
    drumminman Posts: 3,396
    edited October 2011
    Joe08867 wrote: »
    1+1 = 2 :razz: :lol:
    heiney9 Posts: 25,411
    edited October 2011
    Try places like Music Direct or I buy some stuff from a site called Dedicated Audio.
    http://www.dedicatedaudio.com/
    They carry Cardas specifically, that's what you asked about, right?
    Toolfan66 Posts: 17,995
    edited October 2011
    Cardas is my favorite binding post that I have used. I like the Vampires as well but I would skip them for the Cardas..
  • Face
    Face Posts: 14,340
    edited October 2011
  • audiocr381ve
    edited October 2011
    Haha, I guess I was missing something.
    What confused me where those little black plates that the binding posts are attached to. I assumed someone sold single posts with those plates but by the looks of this pic that I found this morning, I was wrong.
    http://www.polkaudio.com/images/showcase/199_18_big.jpg
    Thanks dudes.
  • audiocr381ve
    edited October 2011
    brgman wrote: »
    Yes! Were you able to get gaskets for the passives?
  • fbm211
    fbm211 Posts: 1,488
    edited October 2011
    You may have to mod the holes in the terminal cups to get the posts to fit.I had to drill them out a little to get the eichmann cable pods I used to fit.
    I do know that vampire makes some that fit.Doro knows which vampires are a drop in replacement.
    I see your not going to replace the speaker binding posts..........My bad....You may still have to mod the IC post hole though.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • audiocr381ve
    edited October 2011
    I just ordered the Cardas CCGR-S. Does anyone know if these drop in without modification?
  • Face
    Face Posts: 14,340
    edited October 2011
    You may have to bore the holes out slightly, not difficult with the proper sized drill bit.
