psw 505 NO SOUND
TheDoc
TheDoc Posts: 1
Very new to all of this and was hoping to get some much needed input .
Just opened my psw505 and attempted to hook it up and i am getting nothing.
any insight? do i need to mess with settings?
my receiver is the Yamaha rx-v371
the back has a female port that says "subwoofer" and iv plugged that into the back of the sub
Post edited by TheDoc on
  • rebuy
    rebuy Posts: 695
    edited October 2011
    Is the sub plugged in?
    tonyb Posts: 33,072
    edited October 2011
    Yes,you have to most likely mess with the settings in your receiver and make sure that subwoofer is turned to "yes". Receivers varry on how they do this,you may or may not be able to run it in 2 channel with a subwoofer but for Dolby digital, you need to set that up in the receivers menu. Also, where in the back of the sub did you plug the cable into ?
  • Getdiesel247
    Getdiesel247 Posts: 1
    edited October 2011
    I have this same problem, Sony DH810 reciever. Got moster sub from UPS (amazon.com), open it, unplugged my Klipsch 6.5", put this bad boy in the same place, same connection, nothing changed and 0 sound at 1/2 gain and cut off at 90. Had to turn the reciever from -2db to +10 db and the gain all the way up on the sub just to get some bass. Something is wrong with the input on this (these) subs in ref to how they act with certain recievers.
    My other sub would be way 2 loud at full volume and its 100w rms, this thing is 300w rms. Phase, all that LFE blabla shouldnt matter because I unplugged a klipsch sub and plugged this one it. Not happy at all.
    If you search google you will find a few people with this problem. Some say if you take an ipod wiht a 1/4" to 2 male rca outs and plug directly into the sub you will get loud bass (as a test). I will try that when I get off work but I need to connect this to my reciever not an ipod. I also dont need to run speaker level inputs to this sub (who does that) being my speakers are mounted on the wall.
