embedded in wall speakers (not in-wall speakers)
i am finishing my basement, and the wall where i may put the tv/reciever/fronts/woofer is backed by a staircase with a closet underneath - ie there is 3 feet of unutilized open space behind the wall..
to minimize floor clutter, i know i can do in wall speakers. however, given the empty closet space, i wonder if i can embed the speakers in the wall itself. for example, if i have a large traditional subwoofer, can i cut the back of the wall and slide the woofer back in it so the front if flush with the wall? same question for front left/right speakers. i'm assuming that regular woofers/speakers sound much better than the inwall variety, so embedding these since i have this unutilized space could be an option. thoughts?
Post edited by mga56grg on
I've seen it done on $$$$$$ surround systems in magazines over the years.
I say do it.Most people just listen to music and watch movies. I EXPERIENCE them.
What speakers are you gonna use? Bookshelf or floorstanding?
It will sound boomy without some sort of DSP/Room Equalization."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
thanks guys.
I would probably use bookshelf vs floorstanding. Haven't picked the exact speakers - any suggestions.
what sort of DSP / equalization would you recommend? Since any ports out the back of the speaker will be in the staircase area, i'm sure some sort of adjustment will be necessary. -
A receiver or pre/pro with Audyssey. Or just purchase in wall speakers, there are many high quality in walls available from Polk, Tannoy, JL Audio, etc... http://www.audyssey.com/."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
In an enclosure, don't buy bookies with rear ports.HT SYSTEM-
lsi 9's -
Even if they are sealed, they'll sound boomy. The boundaries will reinforce frequencies higher than what comes out of a port."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I've seen it done w/ ac type vents used to conceal them. For me I would use real inwalls.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
