embedded in wall speakers (not in-wall speakers)
mga56grg
mga56grg Posts: 3
edited October 2011 in Speakers
i am finishing my basement, and the wall where i may put the tv/reciever/fronts/woofer is backed by a staircase with a closet underneath - ie there is 3 feet of unutilized open space behind the wall..
to minimize floor clutter, i know i can do in wall speakers. however, given the empty closet space, i wonder if i can embed the speakers in the wall itself. for example, if i have a large traditional subwoofer, can i cut the back of the wall and slide the woofer back in it so the front if flush with the wall? same question for front left/right speakers. i'm assuming that regular woofers/speakers sound much better than the inwall variety, so embedding these since i have this unutilized space could be an option. thoughts?
Post edited by mga56grg on
    Tony M Posts: 11,625
    edited October 2011
    I've seen it done on $$$$$$ surround systems in magazines over the years.
    I say do it.
  • zingo
    zingo Posts: 11,258
    edited October 2011
    Which speakers would you use?
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    What speakers are you gonna use? Bookshelf or floorstanding?
  • Face
    Face Posts: 14,340
    edited October 2011
    It will sound boomy without some sort of DSP/Room Equalization.
  • mga56grg
    mga56grg Posts: 3
    edited October 2011
    thanks guys.
    I would probably use bookshelf vs floorstanding. Haven't picked the exact speakers - any suggestions.
    what sort of DSP / equalization would you recommend? Since any ports out the back of the speaker will be in the staircase area, i'm sure some sort of adjustment will be necessary.
  • Face
    Face Posts: 14,340
    edited October 2011
    A receiver or pre/pro with Audyssey. Or just purchase in wall speakers, there are many high quality in walls available from Polk, Tannoy, JL Audio, etc... http://www.audyssey.com/.
    tonyb Posts: 33,072
    edited October 2011
    In an enclosure, don't buy bookies with rear ports.
  • Face
    Face Posts: 14,340
    edited October 2011
    Even if they are sealed, they'll sound boomy. The boundaries will reinforce frequencies higher than what comes out of a port.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2011
    I've seen it done w/ ac type vents used to conceal them. For me I would use real inwalls.
