TL350 speakers & banana plugs
explorerhv
explorerhv Posts: 14
getting ready to set this set of speakers up tomorrow, has anyone hooked these up with banana plugs, if so, how - read on crutchfields I think that the blackstone tl350's take banana plugs, but not sure how to connect - the threaded plugs on the back do not seem to unscrew all the way, and the speakers are capped???
thanks
  • explorerhv
    edited October 2011
    thanks
  • dorokusai
    dorokusai Posts: 25,642
    edited October 2011
    Or take a sharp blade, like a razor blade, and slip it under the cap edge....pop it up and pull it off.
