RTi A9 vs RTi A7
With a decent sub able to carry out most LF tasks, and the 9 having two 5 1/4 mids and the 7 having one 6.5 mid, which speaker is going to bring a better bang for the buck? Assuming of course the speakers are going to be set to small.
Post edited by Geoff4rfc on
I had the simular question, and took me awhile to decide. The bottom line is i bought a subwoofer i felt was able to handle the low frequency. Why would i need any woofers that the rt7 or rt9 offer? I went with the rt5 and a decent subwoofer. Works fine for me.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
Questions you must answer first...
What is the purchase for? HT or Music, HT and Music 50/50.
Will you use a AVR to power the towers or a amp? And what kind?
Lastly, will you consider the RTi A5's? If you are going to only use the 80Hz crossover, you might be better served by get the RTi A5 which needs less power to sound great and doesn't have the multiple 7 inch woofers which you will effectively be neutering.
RTi A5's are great and a nice sub will bring the rest of the system together for less money, which is the BANG FOR YOUR BUCK.
I have had the RTi A9's and A7's. As well as RTi8 which is the predecessor to the RTi A5's and is built nearly identical.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
I think your setup is ideal for Geoff4rfc. I did a similar setup with RTi8's for front and rears on a Pioneer Elite VSX-23 with a PSW-111. It was great and got me into the bigger towers.
Now, if you look at you sig, something is wrong.
Onkyo TX-NR807
polkaudio RTiA5(fronts)
polkaudio CSi A6
polkaudio RTiA3
polkaudio HSU VTF2 MK3
Vizio E472VL
ipod-Konnet Dock
Remote=Universal Remote
TV Stand=BDI Icon 9429
When was there a polkaudio "HSU VTF2 MK3" sub?
Don't you mean HSU Research VTF2 MK3?Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
I have had the 7's and upgraded to the 9's. In home theater use the two are hard to tell apart. With two channel or mulit-channel music the 9's stand out. When using a sub in music with the 7's or the 9's, the 9's win hands down.
IMO if using for home theater movies get the 7's. If using for music and movies go with the 9's. Either way they both require a sub for movies.
Search on here and you will find a bunch of comparisons of the two. -
Thanks for the replies. I listen to mostly H.T. but I love listening to my CD's and Internet radio a lot as well. I have a 200 wpc amp to drive the speakers with and I have a pretty powerful sub, that is if you consider an Epik Empire powerful.
I did do a search on Home Theater Mag.com and saw the reviews on each. One of the mentions were; the treble was a bit edgier on the 7 than the 9, not quite as smooth.
Although I've never heard the 5's, I'd think my Monitor 70's would sound as good as the 5's.
I believe the 9 is the direction I'm heading. -
I dont know. There have been guys that upgraded from monitor 70's to RTI A5's and said it was well worth it for the sound quality they gained. More drivers doesnt always eaqual better sound.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Well, if you like RTi A's, then you will love the RTi A9's. The real plus is that you already got a amp.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
If you like the RTiAs, and you want the best bang for your buck, go with the A5s. But if you want the best, then go with the RTiA9s, but make sure you get an amp.
