RTiA9 Mod thread
Yep it is a hoss...
This one is a little different than the first one I did - the 12 uf was OOS on the first one and I used dual 6's so my arrangement was different.
I am getting faster though - clocked myself at... 1 hour and 45 minutes on this one!
Going to throw it on the tester tomorrow!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This was an extremely difficult mod.
Arranging the bypass caps on the stack was... interesting!
I think it would actually be easier to replace the original caps if you could make room on my tower of power!!
Turned out good, dont have enough drivers to test the whole speaker so I am testing each board separately -
SKRILLEX sounds odd with no bass! lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I also find it interesting that the markings on the RTia boards for the values are never matched to the values on the caps.
I am curious to see how they would sound using the board specs...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I would like a little more education on how you tested these crossovers. what is SKRILLEX
I do quick measurements with a volt/ohm meter and will throw on the wt3 with drivers just to see what my receiver will see so I dont blow anything up and then I just run the crossovers full bore for about 20 minutes...
skrillex is a dubstep artist lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Cool to see things are turning out well. I put my a9s into my 2 channel tonight and man they still sound good just a little bright still. Have to say if the mod helps clean that up a bit great speakers equals amazing speakers for the price
Would be easy to clean the highs up - has a 9uf on the high frequency circuit - throw like an ESA series cap in there... change out the resistors on the board and would make for a quick improvement at a low cost!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey, what is the big cap in the center's xover?- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
82uf (csia6)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
skrillex with no bass might actually sound better than regular skrillexMy Living Room
source > Sony DA555ES >
Kenwood GE-74 > Marantz SR4400 > Rotel RB980BX > Polk SDA2.
Pioneer VSX-D909S > Carver TFM-25 > Polk SDA1c.
Pioneer Elite VSX-99 > PSB imageB25.
Marantz 2226 > Polk SDA CRS.
Yamaha RX-V690 > Velodyne Servo F1000.
source > Onkyo TX-DS898 > B&W CC6 (center), B&W DM603, B&W DM601, B&W Rock Solid (rears), B&W AS6.
Bedroom
source > Pioneer Elite VSX-92TXH> ML Quest, B&W DM600 (center), B&W DM601 (rears), Velodyne Servo F1000. -
I disagree with that statement 100%.
Sometimes Skrillex is the best way to start the morning "I want to kill everybody in the world...."... specially for us IT folks that have to stay up late/overnight to fix someone elses screwup :eek: and then be back into the office @ 9 the next morning."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »I disagree with that statement 100%.
That is way too true for those of us in the IT world.
I found using old computer equipment for target practice is very therapeutic. One thing I use to do with one friend is to set keyboards at 50, 100, 150 yards then break out the 10-22's with scopes and bi-pods and call out keys to pick off. -
Personally I just want to re-arrange the keys on a persons keyboard to say things..... use your imagination
just wondering, if the largest cap value is not sufficient, you can link two lower value caps together in parallel for the use of one large cap?
for an example:
if 82uf is not present, you can link two 41uf to fit into that slot? Would you join them as parallel circuit? or just link them together? (or something like that)TV.......................Samsung 46" LCD LN46A550
A/V Receiver.........Yamaha RX-V3900
Amplifier.............. Emotiva XPA-1 Gen 2 for fronts, XPA-3 Gen 2 for center and Surrounds.
BluRay Player.........Sony PS3
Fronts...................RTia9 (modded)
Center.............. ...CSiA6 (modded)
Surrounds.............Empty for now. But waiting for a Fxi A6 deal on polk ebay.
Rear Surrounds.... Deciding if front presence is the way to go instead.
Sub..................... SVS PB12-plus/2 -
Hey Vrm,
what do you run the XO at full bore for 20mins?
any particular reason a guy should do that?
ESR:idea:AVR: Sony 5600ES
Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
More to come :biggrin: -
I believe he does that to conferm that there is no probelms with the xo. That way he doesnt ship them back and have something burn up or short out.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
What he said- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So I was thinking today...
The LSI's have a cascade mid-range as does the RTI A series. I've read some owners swapping the top and bottom drivers to bring the primary driver more at ear level. Has anyone tried this with the A9's? I find my ear level is between the lower mid-range driver and tweeter, maybe more on par with the driver.
Would there be any benefit to swapping the stock driver location? I'm set on doing crossovers in the future but this has intrigued me. -
Anyone...?
I might try this mod this weekend. -
This may be a dumb question, but....the wires running between the circuit boards and the binding posts shown in Vr3m's photo above appear to be very thin. What's the purpose of using heavy gauge speaker cables if the wire feeding the binding post is small in the first place? I've noticed this in other stock speakers also and even my SVS sub internal wiring. Even the wiring between the circuit boards and the individual speakers are thin. Ideally, shouldn't all internal and external wiring be the same gauge otherwise your only as good as your weakest link (or smallest wire)???Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
That short of a distance does not make any distance and you wouldnt know it but that wire is like 3 bucks a foot... crazy right?
It is DH Labs wire, copper silver plated
Will this topic about wire ever be laid to rest?...the wires running between the circuit boards and the binding posts... ...appear to be very thin. ... if the wire feeding the binding post is small in the first place? I've noticed this in other speakers also and even my SVS sub internal wiring. Even the wiring between the circuit boards and the individual speakers are thin...wiring be the same gauge ...only as good as your weakest link (or smallest wire)???
I apologize that what follows will confuse. I'm a big fan of re-wiring woofers, and, depending the range, mids. Your right about the thin wire, etc... At the same time these are very short runs that have affect things little unless you crank your system regularly (like me!).
cheers tonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
cheers tony
This is complete misinformation and retarded...
2" of 18 guage wire can handle more power than you can throw at it.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It just depends on your listening height. I swapped the drivers in my LSi25s because my ears were a great deal closer to the height of the lower woofers than the upper woofers, and I felt it brought things to a better level. Give it a shot and let us know what you come up with.- Computer Rig -
- Main Rig -
I find it interesting that Polk does not cut the lows out of the midrange drivers in the RT series towers...
The RTi12 and A9 pump bass through the midbass drivers like no more tomorrow... strange- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
interesting indeed, seeing as they crossed out of the drivers on the LSi25s.- Computer Rig -
- Main Rig -
Yeah
Actually come to think of it I dont think the A9 allows bass to pass through but the RTi12 definitely do...
The crossovers in the RTi series get progressively better as the line gets more expensive... EX: the A9 uses a poly cap in the tweeter network and highpassed midbasses....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I love to hear others say what I've been saying for over a year... ...in spite of what Polk's website & CS says and and those who believe them. That said RTi A7*s for sure*; and likely their RTi predicessors, 10s.Vr3MxStyler2k3 wrote: »I find it interesting that Polk does not cut the lows out of the midrange drivers in the RT series towers...
The RTi12 and A9 pump bass* through the midbass* drivers like no tomorrow... strange
that said, Trey, when modding XOs, which brand & model cap do prefer for inline use? shunt use?
thnx in advance, tonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
"I" prefer?? lol
Clarity Cap MR lol
What I recommend to folks looking to get their stuff modded -
PX, SA, ESA, MR (any of those depending on their budget) if they opt for a PX I recommend bypassing with a ESA or MR...
For shunt use, depending on what I am using elsewhere - I may just bypass them with a ESA or replace them with a PX series or Solen- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So you don't like PX as an in line?- Computer Rig -
- Main Rig -
