need advice on sub
I need a very inexpensive sub to purchase for the bedroom that system has a kenwood vr6050 with 2 JBL E20. I don't need big or very low freq. just a filler of the lower octaves. any suggestions please ?? no ebay either
What is your budget? Since you are in Canada some of the smaller Paradigm subs are worth a look. The PDR and PS series are the lower end. www.Paradigm.caGraham
thanks my budget is slim to none its only to get my wife by for a bit as cheap as possible
