iPod Tube Amp Thingy + iPhone4
BottomFeeder
BottomFeeder Posts: 1,684
edited October 2011 in 2 Channel Audio
Yeah, I've still got one of those hybrid ss / tube amps & ipod docks. Just love the little guy. While any ipod will play through the system, my iPhone4 won't. I'm guessing that I need some kind of adapter but have no clue.
Anyone have a clue?
"Wish I didn't know now what I didn't know then." Bob Seger
Post edited by BottomFeeder on
    heiney9 Posts: 25,396
    edited October 2011
    Anyone have a clue?
    You talking about the Dared MP-5/Fatman/HTC unit?
    Those were made before the iPhone came out and I have never seen any kind of adapter.
  • BottomFeeder
    edited October 2011
    heiney9 wrote: »
    Yeah, I have the HTC unit.
    & I want a better answer, please! :smile:
  • nwohlford
    nwohlford Posts: 700
    edited October 2011
    One thing to try with older docks is to put your iPhone into Airplane mode.
  • BottomFeeder
    edited October 2011
    Weird, but I'll sure try it. Thanks
    txcoastal1 Posts: 13,499
    edited October 2011
    Heard a Fatman/Iphone- w/wharfedale diamond 10 setup a few months back...not a bad little cost effective set-up...lotta a bang for the buck
  • BottomFeeder
    edited October 2011
    nwohlford - nope, didn't work. Thanks for playing, though.
    txcoastal1 - yeah, I love this little goodie. Shocking how good it sounds. Better tubes makes even better sound.
  • nwohlford
    edited October 2011
    It was worth a shot. Does it work with an iPod touch?
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited October 2011
    If your streaming or playing from your SD card like I do , I've been using a "blackberry gateway" plugged into a aux input then Bluetooth from phone . Cheep ( a
    round 40.00 + power cord , a buck or so) works fantastic on any pre I tried it on. Great sound and very portable. I move it from system to system and take it with when visiting or buying equip. It has worked with any ph. I used with Bluetooth. Using it now with my EVO. Cheeper than any dock I've seen and better sound quality.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • BottomFeeder
    edited October 2011
    nwohlford - don't know. I have an ipod classic & my daughter has a nano & both work just fine. Just wanted to use my iphone & sell the classic.
    soundfreak1 - Yeah, I could probably do that, but would rather use the ipod dock that the system came with. It's easier & charges the ipod as well. & The unit comes with an excellent remote too. But thanks anyway for the recommend!
