Dont know tubes but...
deronb1
deronb1 Posts: 5,021
edited October 2011 in Electronics
Would this be worth it just for the tube/amp section?
http://dayton.craigslist.org/ele/2643626076.html
Post edited by deronb1 on
    Toolfan66 Posts: 17,982
    edited October 2011
    Depending on what tubes they are and the condition the tubes alone could be worth more. But thats all I would be looking at..
  • deronb1
    edited October 2011
    I just don't know enough about it. Those transformers look huge though.
    edited October 2011
    Even though I am running tubes I am still a tube virgin, I lean on the guys around here with questions..
  • deronb1
    edited October 2011
    Gotcha. Maybe George will chime in?
    heiney9 Posts: 25,396
    edited October 2011
    If you know nothing about tubes or electronics, stay away from those old console units, unless they have been refrubed and run recently. You will need some test equipment and a variac to use something that old that has been lying around, etc. Many of those old units don't sound all that great compared to more modern tube gear. Of course there are exceptions.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2011
    Looks as it could give you a very nice watt output, since the power tubes look large and the transformer look large.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • deronb1
    edited October 2011
    Thanks. Actually, I would probably flip them if I could make some cash. Saving for a beefy amp for my 12s.:smile:
    edited October 2011
    deronb1 wrote: »
    Stromburg/Carlson is one of the better one's, but at $200 I doubt you'd make any money, unless you did a complete refurb which would cost money as well. If you could get if it for $50-75 and had the skill to totally refurb it, you might make a little money. If you aren;t a tube electronics guru then pass.
  • deronb1
    edited October 2011
    heiney9 wrote: »
    Ya, no expert at all. Thanks for the info. On to plan "R"
  • stuwee
    stuwee Posts: 1,508
    edited October 2011
    You just missed out on my gem of a console, actually it's the Rolls Royce of consoles a Pilot 1090-A with the SA-232 el84 output tubes, none finer anywhere, sold in less than 12 hours at $400 and worth three times that! But I wouldn't sell it to a gutter buyer, it's going to be refurbed and loved :smile:
    Getting into tubes cheap by gutting a old console is viable only if you know what you're getting into like the others mentioned, I just hate seeing a nice piece of history being trashed just to get that nice tube sound :cry:, breaks my heart!
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • george daniel
    george daniel Posts: 12,096
    edited October 2011
    S-C integreateds are real sleepers,,they will amaze you,,I would hold out for something else,,just my .02
  • deronb1
    edited October 2011
    Thanks George. I am a little confused by your reply though. Sounds like mixed messages?:confused:
  • george daniel
    edited October 2011
    I would just look for something a little "beefier",, unless you like to tinker with old tube amps--if your troubleshooting/knowledge of vintage tube amps are good,,then by all means,pick up a SC or Motorola.Me,, I'm at the age where I wanna listen to what I have,,if you want some vintage tube gear advice--pm jerryj12,,he's a whiz with this stuff,,and he has some SC and Motorola amps.
    mhardy6647 Posts: 34,916
    edited October 2011
    That's a mono console; 200 is steep, I'd opine.
  • schwarcw
    schwarcw Posts: 7,357
    edited October 2011
    I was about to post that bit of information. It is a mono amp, find two of them, and do some refurb and you will have a fine pair of monoblocs. The SCs are will respected and very nice map as someone noted.
    Carl
    edited October 2011
    It does indeed look like a beefy amplifier; the trick may be to find two of 'em.
    I assume the outputs are 6L6.
    There is a place for mono... but I suspect the OP is lookin' for stereo. :-)
