want to mod my fosgate audionics 4200 amplifier with new capacitors.
deseroner
who has modded a fosgate audionics 4200 with new capacitors. i want to bring this oldie to modern capacitors.
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
what size capacitors do i needreceiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
power.c-bpt cpc/ps.soloist ci. -
correct me if i amwrong i see 2 100 uf ,3 10uf and 4 2.2 uf that i can change.with auricap,clarity cap etc.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
That is all I see as well.
it has 4 channels , that schematic is for ch 1 , but i open it , all the same setup on each board, damn this thing is a beaut in side.receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
Also check to see if there are any others in the power supply. Looking at the schematic it seems well engineered.
3x10uf, 4x100uf, is what I see.
And 5 specialty 4x 12000uf/63, 1x 100uf/63 but those are probably electrolytic. -
So...How did the upgrade go? I just bought two of these bad boys and lovin em.2 - Fosgate Audionics 4200's
Denon AVR2802
Martin Logan SL3 - Front mains
Polk CS350LS - Center
Infinity Primus P362 - Rear Surrounds
Infinity Reference 2000.3 - Sides
Martin Logan Abyss - Sub
Wadia WT 3200 Reference Transport
Rotel RCD-1072 CD/HDCD
Sony PS3 - BluRay
Monarchy Audio Model 33 DAC/Preamp
Monarchy Audio DIP Classic
Monarchy Audio DIP 24/96
Ming-Da MC-7R Tube Preamp
Grant Fidelity B-283 Tube Processor
Sony 52" XBR4 -
I just purchased a Citation 5.1 -- can't wait to give it a listen. You did know the Citation 7.1 is the same as your Fosgate 4200
The 5.1 has a little less power. -
I have 2 HK citation 7.1 and 5.1. I opened them just to see inside and to my surprise, both have the same power supply inside. Plus, inside 2 7.1, the newer version has bigger caps. They sound great with my 1c, rti, LSI, and lsim
